73 'rona Posted July 18, 2007 Author Share Posted July 18, 2007 I've just finished sealing all the holes up on the carb to see what would happen... now it doesn't even idle... Its not reading lean just dies as soon as I engage the charger. will keep running If I keep my foot on the gas but it runs in vacuum. Only comes on pressure when I let off the accelerator and then dies. alloy box should be here on friday hopefully that helps... Quote Link to comment Share on other sites More sharing options...
davidian Posted July 18, 2007 Share Posted July 18, 2007 hehe youll wish you went injected soon, mebets good luck dude Quote Link to comment Share on other sites More sharing options...
Mr Revhead Posted July 18, 2007 Share Posted July 18, 2007 its not that hard when thought about and done properly Quote Link to comment Share on other sites More sharing options...
Burntrubber Posted July 19, 2007 Share Posted July 19, 2007 its not that hard when thought about and done properly I spent ages researching till I got all the info I needed to do it properly some of it was so hard to come by! but I got it going but I have since moved onto injection well in the process. Quote Link to comment Share on other sites More sharing options...
nismo.capri Posted July 22, 2007 Share Posted July 22, 2007 This is for a holley carb From http://www.hangar18fabrication.com/blowthru.html So you want to build a blowthrough setup, but have no idea how to setup the carb? Well, just follow the instructions and check out the reference pics and you will be well on your way. Please, read the entire article before modifying your carburetor so you have a full understanding of what needs to be done. Remember, if you modify your carb as per the following instructions, it will be set up for blowthrough, but not tuned for blowthrough. That part is up to you. First, you’ll need a carb. For this article, we’ll be using a Holley 4150 Series 750 double pumper, pictured here. [pic] All the following modifications will work on any double pumper, regardless of size, from 600-850. They will also work on any Holley clone, like the Barry Grant “Claw†Quote Link to comment Share on other sites More sharing options...
AE25 Posted August 5, 2007 Share Posted August 5, 2007 i do hope you have an air bypass valve! when the charger is spinning and your throttle is shut.. that extra air has to go somewhere Quote Link to comment Share on other sites More sharing options...
