filthy one Posted May 24, 2007 Share Posted May 24, 2007 Hey guys need some help? took my wagon for cert today straight through apart from handbrake {but i had'nt fitted it anyway] thought the certifier would have an idea or two. My problem is i need to find a handbrake lever that uses 2 cables as i don't have enough room to run cables in the driveshaft tunnel which means i have to run cables from the rx7 diff under the floor then up through it to the brake lever any ideas ??? So i need a setup that pulls up rather the pulling the cable towards the front AARRRGH fuck that makes no sense Quote Link to comment Share on other sites More sharing options...
blakamin Posted May 24, 2007 Share Posted May 24, 2007 curved teflon-style cable guides? In a lazy arc (like motorbike throttle-cable bits where they join the throttle) like the pics in this link http://www.jpcycles.com/Tech/Articles/Cables.aspx and a floor mounted hand-brake with some minor adjustments to pull up from in front of the pivot-point. edit... HQ-J holden style... right side of drivers seat... Quote Link to comment Share on other sites More sharing options...
CUL8R Posted May 24, 2007 Share Posted May 24, 2007 Think the volvo 240 had two Cables, Talk to Durty he's wrecking/derbying one shortly I think.. Cheers,Chris Quote Link to comment Share on other sites More sharing options...
blakamin Posted May 24, 2007 Share Posted May 24, 2007 My parts merc has 2 cables too... but then they join into one Quote Link to comment Share on other sites More sharing options...
durty Posted May 24, 2007 Share Posted May 24, 2007 Think the volvo 240 had two Cables, Talk to Durty he's wrecking/derbying one shortly I think..Cheers,Chris will have a look if you want, you need them to pull up aye filthy Quote Link to comment Share on other sites More sharing options...
filthy one Posted May 24, 2007 Author Share Posted May 24, 2007 Yes mate that will be sweet if you can check it out Think the volvo 240 had two Cables, Talk to Durty he's wrecking/derbying one shortly I think..Cheers,Chris will have a look if you want, you need them to pull up aye filthy Quote Link to comment Share on other sites More sharing options...
durty Posted May 24, 2007 Share Posted May 24, 2007 will go look this weekend and take pics, have to get pics for blakamin anyway Quote Link to comment Share on other sites More sharing options...
filthy one Posted May 24, 2007 Author Share Posted May 24, 2007 see there are good bastards in the world cheers man will go look this weekend and take pics, have to get pics for blakamin anyway Quote Link to comment Share on other sites More sharing options...
Raizer Posted May 24, 2007 Share Posted May 24, 2007 AFAICR Minis have a twin cable set up, might be something else though Quote Link to comment Share on other sites More sharing options...
Chrome_GT Posted May 24, 2007 Share Posted May 24, 2007 Yeah minis and morris's BLMC stuff have twin cables. Just had a look in the dark with my cellphone to light the scene - pulls forwards not up. Could you get some pulleys and rig something up? Otherwise lined cables as mentioned up there ^^^^ . Places like Safe R brakes could probably make something up for you, they can make clutch cables. Quote Link to comment Share on other sites More sharing options...
durty Posted May 26, 2007 Share Posted May 26, 2007 twin cables but looks like they pull forward, you can have it anyway if you wana try rig sumthing up using it Quote Link to comment Share on other sites More sharing options...
filthy one Posted May 27, 2007 Author Share Posted May 27, 2007 Cheers mate I think i sorted it but if its no good i'd be keen on trying it out cheers again twin cables but looks like they pull forward, you can have it anyway if you wana try rig sumthing up using it Quote Link to comment Share on other sites More sharing options...
