CaMpylobacter Posted March 9, 2007 Share Posted March 9, 2007 Any mofo know what the flow rate of silvertop 20v injectors are? also, when going about making an njection manifold, can you buy bosses to set into a new manifold to suit the factory injectors, fairly easily? any idea on costs etc? choice Quote Link to comment Share on other sites More sharing options...
Spencer Posted March 9, 2007 Share Posted March 9, 2007 around 295cc when I had mine cleaned and flow tested. Yea you can get bosses you going to use silvertop injectors because I'd use top feeds on a custom manifold? Quote Link to comment Share on other sites More sharing options...
CaMpylobacter Posted March 10, 2007 Author Share Posted March 10, 2007 oh they're side feed? Dunno what to use, just researching the use of quads on the pug. can get full silvertop setup inc fuel rail and injectors for like $100. pug injectors are 200cc/215cc depending on type. should be 200cc given it's vintage, although it's ight on the changeover. 295 would be a good upgrade for what I want. hmm Quote Link to comment Share on other sites More sharing options...
Spencer Posted March 10, 2007 Share Posted March 10, 2007 yea boe side feed no good realy aye, top feed is the way to go. Quote Link to comment Share on other sites More sharing options...
eke_zetec_RWD Posted March 10, 2007 Share Posted March 10, 2007 are the pug ones top or side? wt is the port spacing center to center compaired with the 4age? Quote Link to comment Share on other sites More sharing options...
lowlancer Posted March 11, 2007 Share Posted March 11, 2007 Side feed sweet on TB type applications, shit otherwise Quote Link to comment Share on other sites More sharing options...
mikuni Posted March 11, 2007 Share Posted March 11, 2007 I've seen standard manifolds cut up and modified to fit throttles on. Then the standard injector holes are used. Can only be done if injectors are near the head obviously. And it depends on the port spacing aswell, otherwise you end up with a bendy intake. Quote Link to comment Share on other sites More sharing options...
CaMpylobacter Posted March 11, 2007 Author Share Posted March 11, 2007 dunno yet, boe. just thinking out loud for now. off centre though. two at each end kinda thing Quote Link to comment Share on other sites More sharing options...
nismo.capri Posted March 14, 2007 Share Posted March 14, 2007 Food for thought http://www.max-boost.co.uk/max-boost/re ... c-info.xls Quote Link to comment Share on other sites More sharing options...
CaMpylobacter Posted March 14, 2007 Author Share Posted March 14, 2007 I love you man also, thanks for that fuckin' bangin' link! Quote Link to comment Share on other sites More sharing options...
nismo.capri Posted March 16, 2007 Share Posted March 16, 2007 I love you man How many times did your Mum tell you not to drink the shoe polish! also, thanks for that fuckin' bangin' link! No probs Quote Link to comment Share on other sites More sharing options...
