d.p.n.s Posted November 28, 2006 Share Posted November 28, 2006 hi all i after the settings for the crank main berings and rod big end aswell my computer has shit itself and im in a internet cafe so if any one can text me them that would be shit hot dan=021 2140427 allso with new rod bigend shells i tryed to tighten them a little and the crank would not turn at all is there a reason for this or should it be that hard to turn(cant turn at all)to start of with the shells look a wee bit thick to me. thanks and if someone can text them to me .cheers Quote Link to comment Share on other sites More sharing options...
Gaz Posted November 28, 2006 Share Posted November 28, 2006 Ive posted the settings on here or smallford before. Quote Link to comment Share on other sites More sharing options...
cute wee gem Posted November 29, 2006 Share Posted November 29, 2006 Also, the reason your crank won't turn is because the bearings are in wrong Quote Link to comment Share on other sites More sharing options...
Toucan Posted November 29, 2006 Share Posted November 29, 2006 //oldschool.co.nz/phpbb/viewtopic.php?t=7586 Quote Link to comment Share on other sites More sharing options...
d.p.n.s Posted December 1, 2006 Author Share Posted December 1, 2006 Also, the reason your crank won't turn is because the bearings are in wrong what is the right way? cheers Quote Link to comment Share on other sites More sharing options...
Gaz Posted December 1, 2006 Share Posted December 1, 2006 They have grooves in them to locate Quote Link to comment Share on other sites More sharing options...
d.p.n.s Posted December 3, 2006 Author Share Posted December 3, 2006 They have grooves in them to locate yeh i put them in the groves the crank turned over by itself but when i put the pistons in and done the big ends up it wouldnt turn i tryed it with the old bearing shells and it was sweet. Quote Link to comment Share on other sites More sharing options...
Gaz Posted December 3, 2006 Share Posted December 3, 2006 Did you grind the crank and buy the right size under bearings? Quote Link to comment Share on other sites More sharing options...
d.p.n.s Posted December 3, 2006 Author Share Posted December 3, 2006 no thats where i think i went wrong i have 2 cranks and got the mixed up.hahahah Quote Link to comment Share on other sites More sharing options...
Gaz Posted December 4, 2006 Share Posted December 4, 2006 Thatd do it Quote Link to comment Share on other sites More sharing options...
