flipped my leafs but not level!
WildPlumDx
hey guys! i just flipped my leafs again i have it on 50mm blocks with one of the middle leafs flipped but decided i wanted lower and flipped the load leaf the big fat mamma one on top of them all with all the others back to standard so just the load ones flipped! (bottom leaf) anyways its not sitting level aye drivers sides like 20 25mm lower ? and everythings done right maybe its just gotta settle ? anyone else had this problem ? cheers
  • Replies 61
yeah poeple say it is but i cant see how >? maybe the process of flipping them in the vice can be dodge i mean ur relaying on that little bolt to hold everything together so it dont bust open and kill u but once shes all bolted down i dont see any danger ? please correct me if i'm wrong!
yup
flipping the is stupid. so much extra load on u-bolts, and no spring tension as they're just really a bendy piece of steel after that with leaves fighting against leaves etc.
no protection against axle tramp like that either
spend the coin and do it properly, otherwise you're just asking for trouble
how much do you guys lower your escorts by and do u have pics? pm me if anyone has any info and recommendations on this.
im putting 17's on with pumped guards and want it as low as i can... but dont want it rubbing with 5 people in it etc. does adding a leaf actually stiffen it any more then normal or does it just make up for the lost tention by the leaves when they get reset? chur
I lowered my car by 2 inches all round and 33% harder, I have 13 inch wheels with 205/60 tyres, my front gaurds are rolled and my rears cut, my wheels hit my gaurds when i turn some corners too quick and sometimes when i have too much in the back.
Flared gaurds all round would be better but its ok as it is, as when the tyres rub they dont damage it so its ok
yuh, 205s on a mk1 are generally regarded as far too big.... 195s being max
195/50/15 are evn to big on an escort. Front gurads are just too small and rear guards have a shit top which causes mass rubbing insider guard.
