L0WMK2 Posted December 19, 2005 Share Posted December 19, 2005 cars been sitting in the garage for a while since ive been doing some work to it tryed to start it in the weekend and doesnt want to turn over at all thinking maybe starter motor any help? pretty sure solenoid is fine cheers Quote Link to comment Share on other sites More sharing options...
Muzzie Posted December 19, 2005 Share Posted December 19, 2005 cars been sitting in the garage for a while since ive been doing some work to it tryed to start it in the weekend and doesnt want to turn over at all thinking maybe starter motor any help? pretty sure solenoid is fine cheers I assume you checked the obvious? The battery! Quote Link to comment Share on other sites More sharing options...
corrupt Posted December 19, 2005 Share Posted December 19, 2005 yeh, clean the battery terminals, then tighten the leads back on good. Quote Link to comment Share on other sites More sharing options...
L0WMK2 Posted December 19, 2005 Author Share Posted December 19, 2005 checked battery also charged it Quote Link to comment Share on other sites More sharing options...
Muzzie Posted December 19, 2005 Share Posted December 19, 2005 checked battery also charged it How longs it been sitting for?? Good chance you have fucked the battery if it's been left uncharged. Easy way to tell is witha multi meter, or flick the main beams on and shit the starter - the lights should stay on full and bright, if they dim out your battery is poked. Quote Link to comment Share on other sites More sharing options...
Ned Posted December 19, 2005 Share Posted December 19, 2005 did the work you did on it involve disconnecting things? like engine earth wire? starter motor wire? did you check the fuses? sorry if youve checked all these, but it would be handy if you wrote down what you have already checked... i take it its a manual? tow start it at 40k an hour that will get anything to work just make sure its not something silly like a pressure plate thats too big. also check if your engine hasnt seazed for some weird reason.... that could also be it... Quote Link to comment Share on other sites More sharing options...
L0WMK2 Posted December 19, 2005 Author Share Posted December 19, 2005 checked the leads to battery, checked battery, wiring to solenoid and i found i had a loose connection to my block but now its winding over but no fire Quote Link to comment Share on other sites More sharing options...
Muzzie Posted December 19, 2005 Share Posted December 19, 2005 Got fuel spark and compression? Quote Link to comment Share on other sites More sharing options...
L0WMK2 Posted December 19, 2005 Author Share Posted December 19, 2005 just taken my spark plugs out ends totally covered in oil Quote Link to comment Share on other sites More sharing options...
Muzzie Posted December 19, 2005 Share Posted December 19, 2005 Clean and retry Quote Link to comment Share on other sites More sharing options...
L0WMK2 Posted December 19, 2005 Author Share Posted December 19, 2005 done that and still not working Quote Link to comment Share on other sites More sharing options...
Muzzie Posted December 19, 2005 Share Posted December 19, 2005 Got spark at the leads?? Quote Link to comment Share on other sites More sharing options...
kyteler Posted December 19, 2005 Share Posted December 19, 2005 is it actually getting spark? Quote Link to comment Share on other sites More sharing options...
Muzzie Posted December 19, 2005 Share Posted December 19, 2005 is it actually getting spark? Snap Quote Link to comment Share on other sites More sharing options...
L0WMK2 Posted December 19, 2005 Author Share Posted December 19, 2005 whats the easiest way to try and check that by yourself? wouldnt you need 2 people one to turn key? also carby is making a kinda poof sound? Quote Link to comment Share on other sites More sharing options...
Guest escort_boy Posted December 19, 2005 Share Posted December 19, 2005 sounds like ur dizzy is on hte wrong way or leads Quote Link to comment Share on other sites More sharing options...
kyteler Posted December 19, 2005 Share Posted December 19, 2005 unless you can have number one lead with plug in it propped up close to an earthing point while you reach in to crank it over, you may have a bit of trouble on your own. Another option is to connect a wire to the starter terminal and one to the solenoid and then connect them while you're holding the plug on an earth, you will need some decent gloves though if you don't have a switch you can utilise. The "poof" is probably air escaping back out through the intake because it's not firing, and/or your timing is off. Quote Link to comment Share on other sites More sharing options...
L0WMK2 Posted December 19, 2005 Author Share Posted December 19, 2005 firing order is 1243, 1 being closest to radiator? in my manual it says number one lead is at 1oclock on dizzy and 234 are anticlockwise from number 1 but 1oclock is different from which way you look at it? Quote Link to comment Share on other sites More sharing options...
davidian Posted December 20, 2005 Share Posted December 20, 2005 should be clockwise i thought? well supposedly the no1 piston will have the rotor pointing to it at TDC Quote Link to comment Share on other sites More sharing options...
L0WMK2 Posted December 20, 2005 Author Share Posted December 20, 2005 pulled number 1 lead out its getting spark Quote Link to comment Share on other sites More sharing options...
