Ned Posted December 13, 2005 Share Posted December 13, 2005 Hey guys, i'm a n00b when it comes to turbo's etc but heres my story i'm putting a 2T-B into my starlet for now, but want to actually re-build a 2T-G and turb it. now, can anyone tell me what's needed to do this? i know that the 3t turb exhaust manifold will bolt onto the 2t block, so thats a good thing to know any help=awesome chur Quote Link to comment Share on other sites More sharing options...
drftnmaz Posted December 13, 2005 Share Posted December 13, 2005 you'll need oil feed and return lines as well. maybe a 3t-gteu sump will fit? if not the weld a return into yours. as for oil feed i think the 2t and 3t run the same blocks???? so prob just a factory oil feed. i wouldnt bother with a 2t if it was me i'd go straight to a 3S Quote Link to comment Share on other sites More sharing options...
Guest escort_boy Posted December 13, 2005 Share Posted December 13, 2005 but they are FWD arnt they? or 4wd Quote Link to comment Share on other sites More sharing options...
TygerTung Posted December 13, 2005 Share Posted December 13, 2005 3T-GTEU computer and loom and injectors. Also a turbo would be handy. Get the 8.3:1 compression ratio 2T-GEU as well. It's a pretty straightfoward conversion. Quote Link to comment Share on other sites More sharing options...
drftnmaz Posted December 13, 2005 Share Posted December 13, 2005 but they are FWD arnt they? or 4wd 4wd but hey the motor in my rwd 323 if from a 4wd Quote Link to comment Share on other sites More sharing options...
RT Posted December 13, 2005 Share Posted December 13, 2005 i'm putting a 2T-B into my starlet for now, but want to actually re-build a 2T-G and turb it. now, can anyone tell me what's needed to do this? money Quote Link to comment Share on other sites More sharing options...
rxtoy Posted December 14, 2005 Share Posted December 14, 2005 there's quite a few RWD 3SGTE conversions floating around now, they're not the cheapest or the easiest conversion though from everything i've heard. 3TGTEU would be easiest, apparently there's an issue with an oil return line from the turbo and one of the engine mounts but this wouldn't be too hard to get around. they're getting to be a fairly old motor though and semi hard to find. cheers Matt Quote Link to comment Share on other sites More sharing options...
Ned Posted December 14, 2005 Author Share Posted December 14, 2005 well, someone i know has got 5 of them so thats all gravy. i know that they are old, but surely the engine would be a minter after a re-build... one other thing i forgot to mention is that i was also contemplating to not use the fuel injection setup, but go for twin sidies instead... or wold it be to hard to then turb the bugger...? oh, and RT, surely i dont need money for any of this right? i thought it'd be free Quote Link to comment Share on other sites More sharing options...
rxtoy Posted December 14, 2005 Share Posted December 14, 2005 well if the engine's available and you've already got it set up for a 2T i'd say a 3TGTE would be a damn good option, especially with a rebuild. you'd be crazy to go carby turbo though, carbs need to be modified to work under pressure (most carbs suck, this will have air forced in, Zep would know a lot more about this than i do) and you don't hear too many stories about people getting them running just right. when you've already got a factory setup that works perfectly it would take a lot of motivation to kick it to the curb and go to all that work. if you want it enough though it could be done. Yems on Toyspeed would be someone good to talk to about the 3TGTE conversion, he's done one into his ke30, and slonlo (same forum) has also swapped one into his TA23 cheers Matt Quote Link to comment Share on other sites More sharing options...
WDE_BDY Posted December 14, 2005 Share Posted December 14, 2005 DELETED Quote Link to comment Share on other sites More sharing options...
Ned Posted December 14, 2005 Author Share Posted December 14, 2005 RX, i actually ment i know someone with 5 2TG's but no worries so you guys all think i should go for the 3t then... so callum, i should still make the mounts the same as for the 2T that you send me? makes it easier for now while i'm running the 2t anyways. also, word on the street is that these things make ~180 or 170 hp standard, cant remember what they told me, is that about right? do these engines come up for sale quite often? and what's a good price for them? there is one in the new T&E for $600 i believe, comes with ECU and loom. also says it comes with everything for a conversion... but not sure if that means it comes with a box... so i take it i cant use my T50, or would it suffice untill more work goes into it? one more thing for you callum, i dont want to sound like a smart arse, but since my car is a rolling body right now, just waiting for the pannel beater and the painter, wouldnt it be just as easie to mod the tunnel now? save alot of re-painting and disasembling of the car? or is there no easy way of knowing how far to cut the tunnel until the box is in...? cheers guys, your being a great help especially you callum, you've saved my arse quite a few times now! remind me to buy you a beer, or 10, next time your in auckland!! Quote Link to comment Share on other sites More sharing options...
drftnmaz Posted December 14, 2005 Share Posted December 14, 2005 i dont aucally know but i highly dout they make 180hp. i've owned one 3t-gteu those twin spark twin cam turbo ones and its the slowest turbo car i've ever owned. it was in a carina which is prob quite heavy but still only a two door car. (starlet prob weighs half ) and for 600 you should look for a rusted out or de-reg'd whole car so then you got all the little bits, fuel pump, clutch master cyclinder etc... maybe even brakes? Quote Link to comment Share on other sites More sharing options...
Ned Posted December 14, 2005 Author Share Posted December 14, 2005 cheers for that man, what cars to they come out in? Quote Link to comment Share on other sites More sharing options...
drftnmaz Posted December 14, 2005 Share Posted December 14, 2005 ummm carina's and celica's as far as i know Quote Link to comment Share on other sites More sharing options...
Ned Posted December 14, 2005 Author Share Posted December 14, 2005 chur Quote Link to comment Share on other sites More sharing options...
WDE_BDY Posted December 15, 2005 Share Posted December 15, 2005 DELETED Quote Link to comment Share on other sites More sharing options...
Ned Posted December 15, 2005 Author Share Posted December 15, 2005 cheers man! legend! Quote Link to comment Share on other sites More sharing options...
