Is your standard carb auto choke? Use the same lines if so. I know that lots of cars have water lines in the manifold, eg:My 4G63 does, but it ran an Aisian carb, which didn't match up to my weber, so I blocked it off. no biggy
sorry yeah i was looking at the manifold, not paying attention. easiest way to get rid of the chokes is just to take off the flaps, you'll just have to put your foot on the gas until you warm up
take a better picture of the auto choke mechanism and then people might be able to shed osme light on the subject.
To me it's looks exactly as people have already pointed out, it uses the water temp to guage what level of choke to use, so if you inlet manifold is water heated then you can divert or T some pipes off that to enable the choke, if your inlet manifold isn't water heated then just divert the heater hoses directly.
could i just put it in line with it or should i spilt it then go to each?
