L0WMK2 Posted November 13, 2005 Author Share Posted November 13, 2005 cost $90 to buy in nz already looked at it Quote Link to comment Share on other sites More sharing options...
lowlancer Posted November 13, 2005 Share Posted November 13, 2005 Just plumb it into your water lines cunt. Quote Link to comment Share on other sites More sharing options...
esky boi Posted November 13, 2005 Share Posted November 13, 2005 Yea look in the haynes manual under the cooling system section.. has a diagram of whole thing, like where the water flows etc. When I put the 2.0 in the esky it had a 32/36 with an auto choke (orginally manual choke on the 1.3) Il have a look at how I set it up, hold on... Quote Link to comment Share on other sites More sharing options...
esky boi Posted November 13, 2005 Share Posted November 13, 2005 Im assuming a mk2 Cortina should be pretty much the same.. looking from the front of the carb you should have a hose from the outlet pointing backwards on the choke unit going to the bottom connection on the heater, then the outlet pointing fowards on the choke goes to the connection on the intake manifold. Pretty simple, youll need a good length of heater hose to do it (a metre will do) just cut it to fit.. Quote Link to comment Share on other sites More sharing options...
L0WMK2 Posted November 13, 2005 Author Share Posted November 13, 2005 sweet cheers Quote Link to comment Share on other sites More sharing options...
L0WMK2 Posted November 24, 2005 Author Share Posted November 24, 2005 like this? ... Quote Link to comment Share on other sites More sharing options...
Guest WESTCORT Posted November 25, 2005 Share Posted November 25, 2005 get a cheap fucked carb similar to it and change it to manual choke if possible, its more trouble than its worth hooking up the auto choke Quote Link to comment Share on other sites More sharing options...
esky boi Posted November 25, 2005 Share Posted November 25, 2005 Yea bro you've got the idea.. the bottom outlet on the choke goes to the other outlet on the manifold tho (the one that comes from the block) Quote Link to comment Share on other sites More sharing options...
