Guest escort_boy Posted June 13, 2005 Share Posted June 13, 2005 how does a quick steer rack work and how is it differnt to a normal steering rack? Quote Link to comment Share on other sites More sharing options...
atropine Posted June 13, 2005 Share Posted June 13, 2005 well its different in that, you turn the wheel the same amount but the wheel turn faster.. so full lock is less steering wheel rotation.. not sure how they work.. i have a picture in my head but meh.. Quote Link to comment Share on other sites More sharing options...
lowlancer Posted June 13, 2005 Share Posted June 13, 2005 Extreme gearing? Quote Link to comment Share on other sites More sharing options...
CaMpylobacter Posted June 13, 2005 Share Posted June 13, 2005 same principle as diffs - the ratio of teeth from crown whel to pinion changes to give a faster/slower ratio - quick rack = more teeth on the pinion.... thats how i see it anyway Quote Link to comment Share on other sites More sharing options...
Guest escort_boy Posted June 13, 2005 Share Posted June 13, 2005 anybody have a detailed sketch image? Quote Link to comment Share on other sites More sharing options...
lowlancer Posted June 13, 2005 Share Posted June 13, 2005 Quote Link to comment Share on other sites More sharing options...
Toucan Posted June 13, 2005 Share Posted June 13, 2005 Ohhhh geeeesus... havent had such a good laugh in I don't know how long Quote Link to comment Share on other sites More sharing options...
Gaz Posted June 14, 2005 Share Posted June 14, 2005 hahaha. thats class Quote Link to comment Share on other sites More sharing options...
Jerm Posted June 14, 2005 Share Posted June 14, 2005 A rack and pinion setup in simple terms is like a gear and a shaft with teeth cut into it... so to make a quick rack you just need a taller ratio. So the ratio between the turning of the wheel and how far the rack moves horizontally is larger than normal. but any friction on the wheels will be increased by the same ratio. Get what i mean? I think thats rigt anywyas. Quote Link to comment Share on other sites More sharing options...
Guest Eddie W Posted June 20, 2005 Share Posted June 20, 2005 They have one extra tooth on the pinion and the same number of teeth on the rack. the teeth on the rack are loweredd however to accomodate the larger dia pinion required. From memory it drops the ratio from 3.5 turns lock to lock to 2.25. Once you've driven an Esky with a quick rack you'll never want to go back. Particularly on the loose but also I would imagine for drifting. They allow you to catch and balance a slide much quicker and easier. However because the rack is thinner where the teeth are, they are more prone to bending if you hit sometning hard with the wheel. They used to be an arm and a leg in my day but I believe you can get a kit in UK to fit in the original housing. Eddie Quote Link to comment Share on other sites More sharing options...
Guest escort_boy Posted June 20, 2005 Share Posted June 20, 2005 cheers for that eddie w. your full of all the usefull information lol Quote Link to comment Share on other sites More sharing options...
lowlancer Posted June 20, 2005 Share Posted June 20, 2005 Old man Eddie of the North shall be his name. Quote Link to comment Share on other sites More sharing options...
