Mini Conversion.
Guest dreadedretard
Guest dreadedretard
How much would it cost to do a honda city turb engine conversion into my mini??? and what do you think about it??
Could just anyone do it? or would ya need to be all hardout mechanic and shit? cheers.
  • Replies 53
Guest dreadedretard
Im gonna do a conversion like this later on in my life. AT the end of this year i want too if i work the year out and get the fuck outta skool. ill spend all my money on my mini and hopefully get a good engine to chuck in it. dont know what yet... hmm any idea's? so far ive got..
1300 escort
1300 uno turbo
1400 uno turbo
1275 mini engine
1275 metro
1300 metro
Honda City Turb
Guest kornstar
why not work the fu*k out of a 1275, that way its still mini and could save heaps on cert costs... i mean does the average wof man no the diff between a 1000 and 1275, and a fully worked 1275 would piss on all the above. almost :lol:
Guest WESTCORT
ill let you know how my 1300 goes, if i get the pistons this week (cheers kyteler! :D) then i should have the bottom end built within 2 weeks leaving me just to finish off my porting and polishing as soon as i find another drill cause i fried the one i was using..
bore and stroke a 1275 out to 1440, deck 80 thou off the pistons, build a custom turbs manifold and run a t25/t28 hybrid
straight cut 6 speed gearbox from aussie, mad disc brakes, blah blah blaH
AWESOME
or work a 1275, bore it to about 1380 or something, twin 1.5" SU carbs, mad cams
tits as!!
Guest kornstar
AWESOME
I would go 4E-FTE Starlet motor or even a 4AGE. use the complete Starlet package (box, driveshaft, hubs, steering etc) and fabricate a frame to attach it to the front of the Mini.
Callum
Either way dude its not going to be cheap,especially the last idea but you have heaspa options.
pffft, with the gearbox, it'll be fine standard...... back in the day they only put straight cut gears in, and that was just to get the extra 4hp that they drag out....
I know a few race guys that use fully standard gearboxes, they have no problems, just dont be a homo and try and do burnouts everywhere-any car that does that ends up fucking their box, on minis, just make sure you do regular as servicing (i used to change my oil every 3000km) and if you're gonna work it at all then get a decent oil cooler, since the engine and gearbox share the same oil it makes it alot harder to keep the oil in good cond and cool temps
putting a kent in it would be a step backwards, after spending all that money, you'd wind up with the same horsepower as a 1275 engine, and it'd be even harder to work on
holla
Guest dreadedretard
and expensive............... id prob just stick to a good old 1275. a little less work and no problems. just bolt the cunt in and im flying.
Guest blown4
you can buy a whole (mini)subframe set up for a vtec (honda motor :confused3: ) in england,comes with disc brakessaxles,allthe mounting shit for a bolt in swap aparaently they scream along.
