rs2000escort Posted March 20, 2005 Share Posted March 20, 2005 im looking at buying a dohc sierra engine to put in my escort im just wondering if it would bolt straight in or will i have to change to mounts and will the gear box fit and can any tell me the specs thanks Quote Link to comment Share on other sites More sharing options...
RT Posted March 20, 2005 Share Posted March 20, 2005 If you're talking about a DOHC from a Sierra Cosworth then Awesome! But if you're talking about the 8 valve Sierra engine...specs aren't flash.. 130+ BHP and over 140 lb ft at less than 3,000 revs. There's no aftermarket parts available to make em more powerful... not very tunable engines and to quote from classicford mag 'the best place for them is the bottom of the sea' Nobody know's much about them so it's will be a mystery if something go's wrong with it.. oh and it also won't bolt straight into your escort because they are totally different from the pinto. hope i hvn't put you off Quote Link to comment Share on other sites More sharing options...
Hemi Posted March 20, 2005 Share Posted March 20, 2005 is that out of a sierra saphire cos i was servicing one of those and noticed it had a dohc injected 2ltr in it and was thinking the same thing about aftermarket parts and fitting etc Quote Link to comment Share on other sites More sharing options...
RT Posted March 20, 2005 Share Posted March 20, 2005 yeah probably, they came out in limited later model sierras. The 4x4 Sapphire has a nice 2.8V6 in it. and the cossies of course! some later models have a nice injected pinto in them although ours were carbed. And somewhere in all this is the 8 valve dohc 2L.. Quote Link to comment Share on other sites More sharing options...
rs2000escort Posted March 21, 2005 Author Share Posted March 21, 2005 sweet thanks for that and nah didnt put me off i will juat have to give it ago and then tell you guys how it went and how it performs cheers Quote Link to comment Share on other sites More sharing options...
rs2000escort Posted March 21, 2005 Author Share Posted March 21, 2005 do you know if the sierra crossmember will fit or will it be easier just to change the mounts on my escort Quote Link to comment Share on other sites More sharing options...
RT Posted March 21, 2005 Share Posted March 21, 2005 the sierra crossmember will definately not fit in your escort... if i havn't put you off yet perhaps i should try harder? it's not a good engine to put in your escort. They had many problems that were to do with lack of knowledge and maintence with those engines. For all the trouble you're facing putting one in your esky you could easily make a 1600 kent more powerful... or a pinto if you want 2L's. If you want twincams then talk to Artropine and go for the Zetec. Much, much better engine.. Quote Link to comment Share on other sites More sharing options...
Guest Jamezuu Posted March 21, 2005 Share Posted March 21, 2005 They blow headgaskets too, and they arnt cheap. Had one at work, 1990ish glx was a nice car but the motor blew 2 headgaskets in as many years. Have you measured up? the intake is quite big and its mighty wide. But dont let us stop you, it would still go real fast standard. Quote Link to comment Share on other sites More sharing options...
Mr.Mk1 Posted March 21, 2005 Share Posted March 21, 2005 Anyone have pix of one? Quote Link to comment Share on other sites More sharing options...
rs2000escort Posted March 22, 2005 Author Share Posted March 22, 2005 cheers for the advice ay but i will still do have always wanted to so yeh you never know might turn out ok ay if you think of any thing as that sucks aout the motor tell me ay the more i know what sucks about them i can change during the rebuild ay Quote Link to comment Share on other sites More sharing options...
