zep Posted October 6, 2004 Share Posted October 6, 2004 I just finished putting a 32/36 DGV on my car and it's running like crap! Can anyone give me some instructions on the best way to tune these bad boys? Cheers Quote Link to comment Share on other sites More sharing options...
Toucan Posted October 6, 2004 Share Posted October 6, 2004 Webers are easier than alot of other carbs to tune so consider yourself lucky Do what you can to let it warm up so that it idles with the choke in. Wind up the stop for the accellerator if you need to. Now just tune the needle screw valve thing until it runs smoothly. When its running smoothly, wind down the stop for the accellerator untill it sits at a lower rpm. It takes a bit of fiddling to get it perfect. Quote Link to comment Share on other sites More sharing options...
Toucan Posted October 6, 2004 Share Posted October 6, 2004 Also I meant to ask, what kind of air filter are you using on it? If you have just a standard air filter, I highly suggest jimmying up a open style holder thing for it (dont know the name) like I did. Its a bit rangi but you can make it look good and its definately worth it for the sound alone Awesome induction noise compared to a standard air filter unit http://img26.exs.cx/img26/948/Engine.jpg Quote Link to comment Share on other sites More sharing options...
zep Posted October 7, 2004 Author Share Posted October 7, 2004 I've got a ramflow on it. It also has been modded to fit an electric choke. Just need to figure out which screw is which now... Quote Link to comment Share on other sites More sharing options...
Snoozin Posted October 7, 2004 Share Posted October 7, 2004 Lucky lucky you have only one Weber to worry about. With the twin Dellorto DRLA 40s I have it's a bitch to get it running smoothly.... doing without a set of vacuum gauges is near pointless. Quote Link to comment Share on other sites More sharing options...
Guest WESTCORT Posted October 7, 2004 Share Posted October 7, 2004 mmmmmmmm twin 40's... Quote Link to comment Share on other sites More sharing options...
