Everything posted by SiRge
Interesting, however internet tells me it's still not as bad as we think. "Every gallon of gasoline burned creates about 8,887 grams of CO2" So that means a full tank of gas (Say 10 gallons or ~38 litres) produces around 89k grams of C02. More internetting says car aircon units use about 350+ grams of r134. So i mean it's not ultra bad for the environment, worth a few tanks. Then again Diesel is even worse. And how much heavy ship fuel does a cargo ship use, or a coal power plant...
I do genuinely wonder how bad it is compared with how much fuel people waste. I mean carbon monoxide is pretty bad too but it's suddenly ok because everyone is doing it.
This is how people start fires at govt agencies
Progress slowing down, fell into employment however got a couple things done, and ordered, then delivered. Firstly a video of it back in it's hay day for you who don't have a tinfoil hat and use FB. Did: 1) Got the sub-frames out and all the hubs etc. Only have fuel tank and dash to remove now. 2) Bought and received a new engine and body loom. Got an EG9 Civic loom. Few reasons. Currently it's all been done with a OBD0 DA6 Integra loom , new EG9 loom is OBD1 which converts great for a tuneable ecu. The builder of the car originally hacked out literally every wire that wasn't needed and bundled loose wires with cable ties so not really sure what I do and don't have anymore. Finally everything was stripped from the dash so I don't have fans, radio, anything that wasn't 100% needed to run an engine was removed. I'd like to change that a little. 3) Bought a full car bush kit from Energy suspension through Adam @ Speedscience Need: (Not a huge amount is ever recorded on the interwebs about how to modify these era of cars to get any sort of handling performance out of them, so this is all my own RnD) 1) Need to head to PaP to investigate if the Honda Oddysey caliper bracket (You can google it yourself) will space the caliper enough so I can run some spare 96 spec ITR front calipers on EG9 disks. Choice upgrade as I have like 230mm disks currently from an AV Integra, so a 262mm and ITR caliper will make a massive difference. 2) Next on the investigation thing is a retrofitted rear sway bar as it doesn't have one, and I think it would really be beneficial to have one. 3) Shortened shocks for the front so I can lower it just a smidgen more (torsion bar front) and still get good travel (Y) Possibly for the rear as well, but I feel the fronts are going to be more complicated. Idea I'm tossing up at the moment is potentially figuring out if shocks form another car will work. So when I have free time I'll just be continuing on grinding back body rust, and sandblast or vapour blast the sub-frames etc in preparation for POR15 and newly acquired bushes, then they can be stored away in my spare car storage system ready to be reinstalled. Thanks for reading.
Have a look at wof rules but not clear. Rear quarter windows, can you replace them with composite? I seem to recall aaaages ago a friend registered their car as a van or something then suddenly it opened up options for putting blackout vinyl on the rear side and rear window as they pleased. Figured if that were true, then maybe could make a fibreglass plug for them instead.
But just A frame it and risk it, that's what I'd do (y)
Or do a quick heli on sand. You'll see how many rippems were given
Jesse's really shit but really cheap trackdays/potential 2kcup mirage
SiRge replied to DoBro Jesus's topic in Other Projects
Those shocks look perfect. Now re-tub the rear to suit. Weekend job. -
Does anyone know if you can replace rear quarter windows with a composite material instead? i.e took out glass, can I form Carbon fibre in the same shape and slot it in there?
This weekend was productive thanks to a few friends helping (Was on dad duty as well). While a mate was collecting the engine crane, another friend put the wheels on the car and rolled it outside. Some genius thought it'd be a good idea to do a skid (me) so I started her up, sat on the rusty floor and effortlessly ripped a single peeler. Success. All went pretty smooth form here with removing engine, a few shitty wiring examples from the original builder (Wires crimped instead of plugged) but nothing we can't deal with. With minor swearing, the engine was out and it became apparent that the top radiator stay needs to probably be removable. There are scratches up the firewall on the drivers side where the rear engine bracket has about 3mm clearence when trying to remove the sucker. Engine was out finally and the car could go back in ready for me to remove subframes and go on a hunt for some more rust. After all that, no more photos was taken, it all went back inside in a hurry. Spent an hour with it last night getting it to a good position to lift it on axle stands (See: Final resting ground). Plan is to take all subframes and suspension off, I have requested/ordered an energy hyperflex kit from Adam @ Speedscience. will then clean up arms stuff then Por15, install new bush and reinstall to car. Today also bought an engine and body loom from an SIR EG Civic. This will be sacrificed to convert the car to obd1 and also to ensure nothing is missed/fucked from the current butchered Da6 wiring job. It allows me to have free wiring for things like dash fans etc which the car doesn't have... And now for pictures. Rest now sweet Prince. Location of the engine until I can get new bits for it. Should probably do cambelt etc right? During the process, the was left in the trolley jack... Hmm We only lifted the tow hooks. Hmmm, not this side... (Can also see the traction bar & mounts, needs to be cleaned up or redone) Oh, don't even need to get on my hands and knees to see this lol. That bit to the left bottom is bottom rad stay BTW. You shouldn't be able to see light through that other hole...
I'm still waiting to show off my gay projects and compare them to your gay project. Reminds of one of those classic American garage project tours. Could easily do one in Wellington
The n360 chassis is a real worry. If you chop the roof off and sit in the car, the floor bends. It makes a new definition of unsafe beyond everything I've seen before
Could you add additional side intrusion into the door? I'm semi considering that option on the crx
I don't think many of those people are around much anymore. But hopefully I can do it justice
Adding a rollcage then adds much more complication. Fixed back seats, harnesses, authority card, actually attending events. I was thinking a half cage as it didn't come with a back seat so may as well utilise it somehow
More than happy for someone to show me how to do metal work and rust repair. I got no idea so winging it
After watching that rookie car YouTube guy B is for Build take out a car window ages ago in one of his vids I thought fuck it, how hard can it be. Success. Found some rust hidden by plastic panels too. Well, there used to be metal there...
- 5 replies
Yes plastic guards, plastics nose cone, plastic headlight covers.
Yea that's about right, turns out my brother in law has known him for the past 10 years too (he organises the air strip for jet car testing) Hoping to pull the motor soon and tidy up some of the crude hammering marks
Mate came over this arvo and after much messing round, finally after replacing the spark leads with random I had spare it fired first pop. Right now I know it runs, time take it out and clean up the engine bay and subframes
Yep, been parked up for 8 years
Discuss here my problem with Honda ownership etc
Fleet expanded. Discuss - It's a 1985 Honda Crx, bought it for a sharp price. Its a ex drag hack from a guy on nzhondas Deanis from 2006. It had a feature in July 2007 performance car, yet to find a copy. Its best time down the strip in its hayday was 12.7 I believe. It had a high comp B18cr (kinda), quads, LSD box, super light wheels and drag radials. Current specs are aporox: - Poor man's type R engine - Non LSD box - Rust - No wof and Dereg, but has a cert Plans are: - De-rustify - Get it legal (needs at least washer bottle + motor, quieter muffler, 15 inch wheels, B pilar plastic) - Tidy up and add a couple niceties back in like carpet and a windscreen fan. Will try redo wiring and tidy engine bay. - Later - try add quads back, needs exhaust headers, get an LSD. Garage space at a premium Just fits Now to get it naked to make more space
- 5 replies
