dave123456789
Everything posted by dave123456789
2 Strokes, whats the biggest, badest / easist??
dave123456789 replied to Seedy Al's topic in Tech Talk
...win -
AUCKLAND MONTHLY MEET - Tues 19th Oct
dave123456789 replied to EURON8's topic in Upper North Island Region
No its not No, its going back to tuesdays. Wednesday is a rain day/tom is in auckland but doesnt come anyway day Im actually out in south head which is probably another 20-30 minutes which is a long time in the land boat with no radio/door seals/exhaust leak. Should still be there though -
I recently got the prince back on the road and semi reliable so may head down. Farken huge mission though from helensville. -
why not? its got a craptastic 3.3 in it currently
hey guys i own a 1966 prince gloria and need to upgrade the front brakes to something better as have a holden 308 to repower with. where do i start? do i just pull my brake setup off and take to pick a part to find something that will fit but is disc?
take carb off, pull apart and go nuts with some compressed air.
Yea you just cut the flare where the door ends and attach that part to the door. could you chuck up a picture cause depending on car/how much it overhangs it could end up looking stupidly gay
I think i know what you mean, it overhangs a bit so door wont open when arch is on? depending on how much is covering door could make it two peice like evo 5s etc otherwise get some fibreglass matt and resin, chop the center out and reshape the arch so doesnt go over the door.
do anyone know a replacement for toyota 2k,3k,4k engines?
dave123456789 replied to mohdoc_1985's topic in Tech Talk
4age + carbs = win -
hey mate what does that power booster do? i found one floating around the engine bay of the prince and was stuck down below the battery. never bothered to hook it up.
measure front springs with car jacked up, remove springs and cut a bit off them as long as you dont make them shorter than when you had the car jacked if you understand? shouldnt have to cut much if you only want half an inch
Car dies on slight throttle, fine if i mash it
dave123456789 replied to dave123456789's topic in Tech Talk
what im trying to get at is had it suddenly just started doing this? Yea it had just randomly started doing it. I put it all back together and the idle was about 300 higher than usual, put it back down to 7-800 now runs fine. Must have been some stuff got sucked in when the fuel was cut off and it was just pumping air through it. -
There was a small bit of dirty stuff in the carb but nothing was blocking the gauze. Went to town with compressed air and am going to put back on car again in a few minutes. What do you mean by valve? you mean the part the suppose to let the lpg in? The car idles fine and runs the same as always its just if i try to gently raise the revs it will die. -
Yea car use to have LPG but now just runs on gas as lpg cert expired 10 or so years ago. Car does have one of those glass filters but thats it. Car was fine before it died now its acting weird. Pulling carb apart right now. -
Hey guys, i took my car out today and got a new wof/reg and on the way home was mucking around with the GAS/PETROL knob and left it on gas so my car never started then the battery went flat. worked out what I had done wrong and roll started it back into life although now when I give it light throttle as if I was leaving an intersection it dies but if i punch the gas down a fair bit its fine. Am going to pull carb off tonight and give it a clean out since i am suspecting that thingie that squrits petrol when the throttle is applied (very technical terms ) is blocked since my fuel tank is full of crap. Any ideas what else would cause this? car drives fine and doesnt die when shifting gears its just the light throttle causing problems. 3.3l vauxhaul engine zenith carb. thanks. edit: dont tell me to always mash the gas pedal, clutch already sad
The regulator is a big box about the size of a packet of cigs. Ok i will take my alternator off and check those things that you mentioned. If it is truely stuffed i'll hunt around for something that will either fit in its place or i'll have to make up some new brackets. Gutted was hoping that this would be a nice easy fix. Thanks for your time
Its externally regulated, the warning GEN light goes out and is completely out. Just checked it in a pitch black garage. Thanks for you help so far, been pissing around with this all night browsing google on the laptop trying to get it sorted before I have to pay someone to do it.
Ok with the meter on the alternator case and negitive battery i get pretty much nothing, highest was 0.01. with the meter on the alternator positive and the positive on the battery i got 0.08
I chucked the meter on the positive on the alt and earthed the other end and its giving pretty much the same readings, all way too low to charge the battery. Also that 13.5V with nothing on is more like 12.7-8 at idle and low 13s with revs. I guess this means my alt is stuffed?
Hey guys I have been trying to work out why my battery doesnt charge. It charges at 13.5V with no lights etc on but as soon as I turn my lights on it dips to 11.8-12.3 if I rev the shit out of it. 3.3L vauxhaul motor
I use to run 185's on a 8inch wide rim and was mint. Never had any problems with cops/wofs or tires popping off beads.
I have the same problem in my prince gloria although when I am driving it goes up to about 12.5 on the gauge and sits under 12 if I drive with lights on, cant use my car at night
