nick_m
Everything posted by nick_m
I'm not really sure. I'm willing to spend decent money on a good setup, however I don't have decent money at the moment, as I was made redundant not too long ago and haven't been able to find work again yet. However, get your mate to give me a price and I can consider my options. $800 plus shipping, its in chch. Seems to be about the going rate for a DE wth loom box and motor. I sold mine for $700 a while back.
wow 280mm disc under a 13" wheel is certainly impressive. As most have said there shouldnt be any issues with a 260mm disc, it seems to be the norm
Yup, RWD Block or nothing, unless your plan on running a non sr20 rwd box behind it with a adapted bell housing. Then it would just be the intake to contend with. For ease just settle for a rwd one. How much are you wanting to spend, I know a mate who is wanting to sell a s14 sr20de with loom ecu and box. Not sure what he wants for it but can find out
I have a set of wilwood 4 pots and 260mm rotors. Have only done a test fit, but I didnt see any issues with diameter. I had a issue with the outer pistons hitting the back of the wheel but datsuns have shallow backspacing on the hub. Will be able to confirm for sure in the next month or so
Thats awesome, I just bought some second hand TRS front slicks for mine. Bout to head off this morning and order my 13x9s. Going to be good to get them on!
So not racing tomorrow then?
YEAH BOI!!!
I reckon vq or vk. The VK is pretty much a VQ with 2 extra cylinders. They are awesome, I think i've heard internet rumors that the vq 350z box bolts up to the vk as well,
Agree with DJZ it would probably still be lighter than a cast aluminium one. Looks like KPR makes his out of 1.6/2mm. Hopefully he'll chime in and answer
Are you talking a manifold with a full plenum? Dont see why not, KPR Made one for his 4age turbo im pretty sure. He also made ITB ones too It will be heavier and may get a bit hotter after long sessions of hard driving, but probably unlikely itll get hot enough to cause any problems (unless you touch it). The worse thing is the stainless wont absorb the vibrations as well as aluminium so it might sing a bit
haha fair enough
May have missed it but are you moving the front eye up too? Only reason I say is by moving the back spring eye mount only up you increase roll understeer which means the harder you corner (more body roll) the more in will understeer. Not ideal, but whether you have changed it enough to make it understeer a apprciable amount more than a stock 1200 I couldnt say.
Cool thanks, I tried to make it as simple and strong as possible, Thinking I will go to Two bars, would probably bother me if I didnt. Will get some pics of the underside of the four link as soon as I get a chance. Hoping to chuck it up on the rotisserie to strengthen the four link mounting and seam weld the body. Want to add some gussets to the link brackets and tie the four link brackets to that lateral bar. Was a little bit of an after thought so just thinking of a good way to do it really. But yeah agree definitely want to make those brackets as strong as possible. Things I would do different on 4 link Make the body brackets 75-80mm wide. I made them 50mm which meant the boxes were a bit borderline for link bar clearance, going by how well you can cut and how short your panhard bar is. So the boxes ended up 80mm to give me more bar room and the brackets are only 50mm. Thats part of the reason I made the boxes 'T' shaped. Also means I can adjust the top and bottom bolts from underneath the car without help from a second person. Wasnt really an issue on mine as its a four door and probably could just reach through the back door if the bolt had to be adjusted from inside like a typical setup but it made it tidier because of the 50 to 80mm box to braacket difference. Mount the coil overs on the top or front of the diff. This would have meant I could have mounted the cage to the rear strut towers. Because I mounted it to the back of the diff I couldnt because the cage isnt allowed to go past rear axle line. Fuck up on my part. Should have read the book better!
Yeah a bit slutted really. $600 vs $1200 for a ALtezza vs S15. Would have been nice to run that. Hope I dont blow one up. Not sure what the best route for close ratio goodness is. Dont really need a 6 speed as the 1st gear would be useless on the s15/altezza boxes with the final drive Im running anyway but there isnt really a lot of options for strong 5 speeds with easily available (prefereably cheap) close ratio kits for it
LEft on list.... Still quite a bit. Mount pedal box and plumb everything Sort Gearbox then mount sr20ve and new box - FWD VE had Different mounts to RWD SR20DE Get Fuel Cell Mount/plumb Get wheels/semi slicks Mount flares to suit wheels. Get link ECU Gauges etc and Wire Rebuild Diff with My LSD - Mount Rear Brakes. Mount plumb Hyd handbrake. Lexan windows Air filter/plenum Exhaust inc Manifold Paint Probably MIRRIONS of little jobs I have missed as you can see there is a few expensive items left on the list. Aiming for 6 months time but it will just come down to money really.
Started road car with occassional track use turned into Full race car. Has reg on hold so it would only be a cert and authority card away from street legal though. Thanks, loving the fab work at the moment (up till the arc eye) its all cool stuff at the tail end of the fab work so its been pretty easy to stay motivated. Its pretty sweet looking at it all caged out, thinking shit yeah, I might actually get to drive this thing again!!
Only thing left is the bars through to Strut towers. and tags to A and B Pillar. Everything else is in and welded. Wanted to do two bars to each strut tower but the lower bar on the door X where it meets the A pillar bar was such a Slut to weld. Thats how I ended up with Arc Eye. Trying to cram my Head in a small space to see where the gun is actually pointing! Think I'll just do one upper bar through to the strut which will meet at the top of the door x Is a second bar really that much benefit? I will persevere if its really beneficial. But it will be a slut.
Cage is tantilisingly close to being finished, Was hoping to have it finsihed by the end of today but my arc eye got worse. It is gay, I dont recommend it to anyone! Still have anohter week of holiday left so should be finished by the end of holidays. Should get the Pedal box mounted too. Which was the original holiday goal Also had a wee set back. Was hoping to run an altezza box with some s15 6 speed bits to mate it to the sr, as the are the "same" box made by aisin. Turns out internally they are the same . The castings are slightly different enough to be a pain. I.E S15 bits mostly bolts up. So that needs to be sold and a new box sourced. Probably end up just saving up and getting a s15 6 speed, as thats probably the cheapest easiest way to get close ratios
Rollcage is all but finished. Just got to go through the firewall to the strut towers and im done .......... However I decided a good dose of arc eye was the order of the day so wont be doing any rollcage today! Still hoping to get it finished up by the end of tomorrow. Hopefully ill get my wilwood pedal box mounted by end of the week too So will smash up some pictures in the next couple of days So stoked to see the cage in there. Finally starting to look like a race car instead of the primered shell that takes up space in my garage! It might even get finished one day!!
that would depend your piston/rod combo and intended revs. I would probably be inclined to leave it as the gain would pretty minimal in the grand scheme of things and you would be absolutely slutted if you destroyed an engine, they can sometimes go in a big way when it happens too!
going space framed now right?
thats quite a large hole there mr bubbles. Put the hole I cut to shame. I look forward to seeing how you fill it
missing a few pictures of late, reasonable amount of work done that isnt shown in pictures. Roll cage is progressing pretty well. Hoping tomorrow to drop the cage through the floor and weld the top. then will flip it back up and do door bars harness bar and strut bars, then it should be all finished ready for homogulation. Probably a good few days of solid work left in it though. Will get rouns to pictures shortly
I sort of came to that conclusion too before I even did the CFD stuff, Was pretty much just fucking around with it to avoid work! Was going to go for as big a plenum I could fit, which dont think will be huge due to space. I CFD'd the dual plenum more out of curiosity as to whether it was worth it, but bit hard to get any meaningful results with the CFD I used. ^was just Floworks (may have name wrong) it came integrated with solidworks 2010, nothing flash. Basically demo mode, need to spend more money to get anything useful really.
