Everything posted by cletus
Just keep in mind if you change it, then it's a modification post 92 and it would have to be certed as per the rules of now
Will be fine as its pre 92. Date of first registration proves the belts are fitted prior to 92, as it would have been a requirement to have lap and diagonal belts fitted when it was first registered in 89
I think the ones I was talking about were a much smaller seperate handbrake caliper that were no good I have certed something with those 4 pot calipers with the handbrake inside, I have a vague memory of the handbrake lever ratio having to be spot on or there isn't enough force for them to work properly
It's at the stage now where it looks like I've done fuck all Which is sort of true. Have been too busy to get a lot of time on it But have been chipping away at small jobs Carb rebuilt Alternator mounts made Throttle cable done Mod and painted the carb hat Calipers cleaned up and painted Radiator finished Hose shapes mocked up just have to find something that sort of fits Turbo oil drain 90% sorted just need a fitting for the block end Takes ages when everything needs blasting and painting and then it seems best to leave it for a week to harden properly
- 128 replies
- 56
Use a cup brush, any bog that doesnt come off must be stuck well enough to stay, more bog over the top, done. I'll show myself out
I'm hopeful, although realistic about it not being, as effective on a petrol engine. Chev came with a set of new unused headers that get rid of egr. needs all the help it can get to use less fuel haha
I had a customer get caught out by that rule, he'd had a full turbo back flash exhaust fitted on his late model v8 landcruiser and didnt have the dpf any more... They are quite expensive new, apparently. haha
Egr blocked off on my diesel van made a noticeable increase in fuel economy as well
Have a look in the CCM it specifies what size bolt etc they need to be Be aware if you are making your own, the welding doesnt agree with a high tensile bolt Also threaded link bars often come loose with articulation, a solution is to use a heim joint /rose joint/spherical bearing at one end for movement and a bush at the other to reduce harshness
Is the 20v head frowned upon in 4age circles? I haven't had much to do with them apart from a local bogan I went to school with had one in a ratty DX corolla and it went quite hard for what it was. I think it ran high 13s or something? And could do burnouts in 3rd gear which is the true measurement of hp
or perhaps adding an extra intake valve? 5 per cylinder for a total of 20 valves
- 124 replies
I should be clear, "inverted" in this discussion is relating to leaf springs with a curve going the wrong way, not flipped, ie upside down, that is 100% not legal
Also the spring design plays a big part in how something rides, especially when someone resets them Ie a lot of commercial van or ute type vehicles have a dual rate leaf pack where there is 2 or 3 thinner springs, and 1 or two thicker springs like the van ones earlier in the thread. Unloaded, the suspension is just using the softer thinner leafs, then when you load it up, they sit down on top of the thicker "overload" leafs If you reset them and the main soft springs are then sitting on the overload springs, that makes it really stiff , same if they are reset higher and the overload leafs are sitting against the main leaf Most car springs just have a pack of the same thickness leafs
It's one of those things that "works", but is not ideal. A normal leaf spring gets longer as it compresses which pushes the shackle away from the leaf, and the spring eye at the shackle end gets closer to the chassis. When a spring is inverted, as it compresses, it gets shorter, which pulls the shackle straighter, which wants to push the spring eye back down away from the chassis, opposite to where the spring wants to go I dont know how much actual difference this makes to how a car drives or whether you can feel the difference, I guess you would need to do some proper back to back testing to ever know. But I doubt anyone would ever bother because someone who is happy to run a leaf spring inverted , is probably only concerned with how they can get a vehicle low, as easily as possible, not make it handle well No factory vehicle , performance or otherwise, has leaf springs that are inverted as far as I know
Funnily, theres nothing in the rules that say they cant be inverted. but it's not ideal, the spring and shackle start working against each other. usually if someone wants to go past 'flat' then you get the eyes reversed instead of making the spring go the wrong way And as @Bling said add a leaf to make up for the reduced travel Yes on the 40mm droop requirements, same rules apply
Everything. Front, back, both sides, interior, engine bay and any visible mods under the car is the requirements for photos the certifier has to supply with the paperwork
I was going to suggest a hairdryer or something to warm up the rubber to hopefully let it relax into it's new position. But then I thought nah nah poor old sheepers has had terrible glazing related luck with this car and that will probably melt his side windows or make them turn purple or shatter or something. So dont listen to me. Then I saw your wheels again and thought they might look good with these on to break up the blackness?
Yeah the biggest issue /most asked question I get is wheels- if a car is certed on 15x8 wheels then under the old plate deal it was a free for all as long as the wheels were 15x8 then you were sweet Now there will be pics of the wheels on the cert, I've had dozens of people having a moan that they wont be able to swap wheels. I dont think the intention with the old plate system was to allow any wheel of that size to be ok but it has become that way, I rang LVVTA and asked what the deal was with different wheels of the same size on the new tag system and the answer was "should be ok" So I guess we will have to see what happens. I personally dont think it should be a free for all if just the size matches, as there are many situations where changing wheels even with the same size causes issues, had a chev truck come through the other day with same size wheels as cert, but the load rating was way less than the GVM Stud length, wheel nut/seat type, and offset differences causing tyre rub are other potential problems I had a guy with a low rider with tiny tyres and cheap knock off rims which failed on a few issues cert his car on 14x7 alloys with some adaptors so that the cert appeared to be for the wheels he wanted, which didnt comply
I got charged $2800 to blast underneath and engine bay, paint the underside black and prime the engine bay. Then I spent another $250 at the painters for them to fix the primer overspray all over the black underneath Then I had to paint the parts underneath that they missed And fix the ripped hoodlining. Autoblast in glenfield should be avoided at all costs
I wouldn't cert them. Other certifiers might, I dont know. What sort of car have you got? A set of aliexpress shocks seems to average $700 by the time they are here A set of BC retails on average $1700 , but I have heard of them being a bit cheaper A cert is going to cost around $650 regardless of what brand So you might save a grand if you can find someone to certify them, but you are likely going to need another set when they spring a leak in 6 months time, or the lower bushes give out, or the piston falls off the end of the shaft or the car handles like shit or whatever. Then if you get sick of buying replacement maxspeedingrods and put some BC's in it then you have to pay for another cert because they wont match the photos on the cert
I dunno, I guess if the certifier missed something and there was an accident due to that then they would be held responsible as well as being injured
Yeah that has been a consideration, one of the reasons for setting up my own workshop was to avoid issues around working at other peoples shops, we have to be careful on what we road test as well, if we find a fault that could possibly cause an issue then we cant test drive the vehicle or complete the road testing until its sorted out Stuff like that, and all the small procedural steps all adds time and dramas though, people get annoyed because we might get a car that for some reason cant be driven for a perceived small reason (ie a broken brake light switch) so they repair it and bring it back and then it fails the brake test so they have to bring it back again, meanwhile costs are starting to stack up because the speed limits in Auckland changed and it takes an hour to do a road test so before you know it, a cert that used to cost $400 10 years ago now might be $1000 and "it's just a 308 in a commodore, some came factory like that, why is it so hard " and so on Rant over, haha.
- 9032 replies
Yes there is the technical advisory committee that meets once a month to look at design approvals, people wanting do do different stuff that isn't covered by the rules or is outside of what the rules say, things like that
