cletus
Moderators
Everything posted by cletus
  1. worst case, you could do what a few people have had to do, chop the strut tube off, get a another pair of stubs and weld as described above Have you got a chassis number on paper. or are there any numbers on the frame? there must be something if someone found its id before, unless he was telling porkies. if the certifier had access to the system (landata) it would have the same details as a vtnz/nzta agent looking at it
  2. I have T3 adjustable rear arms for my 4 link on the KP - they're solid alloy machined to accept the rod ends (teflon lined etc etc) so are these now an expensive paperweight? only applies to front susp arms in certain configurations, if they are rear arms, and made well, youll be sweet.
  3. viewtopic.php?f=17&t=24361&start=20 some pics in here of what im talkin bout willis
  4. Righto at the moment, these struts cant be certed due to what ryan said- the strut tube is welded to the cast spindle. this has been a rule for a long time, that you cant weld to a casting or forging. The factory one is welded to the cast part- but because that is done by the vehicle manufacturer ,its ok. There arent heaps of vehicles affected by this, the only ones ive come across so far have been ae85/6 toyotas and late model hondas, they have a cast steering arm welded to the shock body. not just bc either, there are other brands which use the same construction. the ones ive certed that have been welded together have been done how ryans was done- slip the tube over the original (shortened) shock tube, tig welded around the base(10-15mm ABOVE the cast part not to it), 4x plug welds around the top, then crack tested. last time i spoke to the tech guy at LVVTA, he said they were working on it, trying to find out more about the welding process BC uses
  5. cletus
    Rb30 vs 308
    i remember hearing 308 statesmen with twin pipes when i was a kid and thinking they sounded funny. fitting old style chev in a commodore is a bit of a prick, chevs have starter on our drivers side so it interferes with the rack, you can buy a chev into commodore kit but it spaces the front x-member down about 40mm, so you cant lower it fuckall and needs a longer steering shaft. ls1 however, is a better idea, they haul ass in early commodores and moving the starter to the other side is not too hard, and its easier to find a good runner that doesnt need a rebuild
  6. cletus
    Rb30 vs 308
    youl go faster cheaper with rb30 theres heaps of them in `straya running fairly quick times yu1Totn7kyo
  7. icon signs in east tamaki would be another one to try the guy who owns the business (michael) has high standards when it comes to workmanship
  8. splendid looking motorcar, chap.
  9. jet extensions move the secondary jets back a bit in the bowl so under hard acceleration the jets dont get uncovered by fuel bowl vent extensions= in my case 2 rubber hoses off the bowl vents that extend into the hat. improves the pressure signal to the bowls by facing the inlet hole straight into the airflow. i believe in some cases the air going across the top of the vertical vent tubes acts like a venturi and can reduce the pressure in the bowl very slightly, and it wouldnt take much pressure difference between the bowls and the rest of the carb to affect fuel flow thru the jets. it must work, removing the extensions alone was enough to take it from the 9.8-10.0 figure, to about 10.5- 10.8, the rest was the jet size change
  10. from LVVTA website- Do I need LVV Certification if I have a Modification Declaration Certificate? Cars that were modified prior to 1 January 1992 were issued with a Modification Declaration Certificate at that time. The Modification Declaration Certificate is valid as long as the vehicle is continually registered and until changes are made to the vehicle, at which time the vehicle must be LVV certified and issued with an LVV plate. Provided the vehicle is still the same as it was in 1992, the Modification Declaration Certificate continues to be valid today for WOF purposes. The WOF issuer is able to check with LVVTA or NZTA to verify details on the certificate.
  11. yes should be attached with 4 rivets to a part of the body/chassis that cant be removed.
  12. PVCR drilled to 2mm, near enough to .078, 6.5 PV at fist i thought id cocked that up, full load AFRs went to 9.8-10.0 ish, was like someone pulled the choke on. i had bowl vent extensions on it which the other carb needed, took those off and went down a jet size primary and secondary and its now at 11.2. still on the rich side but its safe. goes good
  13. Sent carb away to a guy in Oz to sort out, still waiting to get it back, got sick of not being able to drive it. So i bought a shitty old 600DP holley for it off trade me. stripped it, fixed all the fucked parts, milled choke tower off, drilled out power valve restrictors, jetted to suit. spent a few hours with a wideband hooked up to it today, the shitty old home built holley works better than the flash ''designed for blowthrough" Demon carb ever did. drives much better and is better mixture wise under boost. Hopefully the modded Demon works as good as this when i get it back....... Anybody trying to do something similar, these are handy websites to look at... http://www.hangar18fabrication.com/blowthru.html http://www.theturboforums.com/
  14. if you could see what number is on it or even a pic would be handy. Might be something thats prior to me starting certing that i dont know about. It may be the 2nd page in the formset, that lists all the mods on the car, usually is filled out by the certifier.
  15. ive never seen a form like that? maybe a certifier made one up and gave it to you? its a good idea actually, would make life easier identifying whats been changed on a car
  16. no you should be sweet
  17. what you are describing would be fine. its only required on one side of the rail. an alternative is to cap the top and bottom part of the [ instead of the vertical part personally i think it looks neater to do just the inside of the [ (or what you described, completely cover the inside join) when i did the chassis join on a previous project it was a box section, cut it in half, cut 100mm extra from the inner wall each side of the join, fish plate on the inside of the rail, then folded up 200mm long [ section for the inner wall and tig it all together, was hard to see where it was joined
  18. yep thats fine, cut it on an angle, butt weld it back together, then a fish plate twice as long as the height of the rail over the join. there are other methods in the book but thats probably the easiest to explain/do
  19. depends, what are you looking at doing? any structural modifications need cert. The frames measure 65(w)x45(h)x1.2 wall. If I replace them with something that's 65x25x5mm would that be ok? What sort of strength are we looking for, second moment of area? what is the application? what part are you replacing? the whole chassis rail? or just a part? on an mx5? would probably need a certifier to look at it to give you an accurate answer. Supplying engineers calculations will be helpful ie what brockolee said not at all..... im still learning how to suck an egg properly
  20. better be a valiant ute, Bart.......... hahaha
  21. it does say that but only applies to heavy vehicles and PSVs (buses etc) top of the page rh side, the bit that applies to us is "general vehicles"
  22. Does this mean the wastegate exhaust pipe needs a muffler? Also. Would these be cert'able if I had them redrilled to 4x114.3 http://www.trademe.co.nz/motors/car-parts-accessories/wheels-tyres/nonalloy-wheels/auction-443329315.htm depends who you ask......... that paragraph says the wastegate has to have its own exhaust system, it doesnt mention anything about a muffler being a legal requirement. also,under test conditions, the wastegate wouldnt be open, there is no drive-by or full throttle noise test. as for the wheels, depends on how the studs holes are made, usually steel wheels have a pressed raised bit where the wheel nut goes, there may not be enough thickness to drill the hole and taper it
  23. depends, what are you looking at doing? any structural modifications need cert.
  24. just checked the emissions standard and it was updated in dec 2011 cat requirements 2.5 http://lvvta.org.nz/documents/standards ... ssions.pdf
  25. all custom front suspensions like this have to be individually approved by the TAC (technical advisory committee) they would advise on any requirements to do with crack testing, geometry changes, stuff like that looks like a good idea for making a beetle handle better
