Everything posted by Spencer
oh and brad best trumpets out have a full return lip on them as most air is sucked in from the side like this
^ yea a device with a accelerometer will do the same thing and is ideal but cost $. Same results with a crusty laptop hooked up to the spark output ftw just cant take the numbers it puts out as gospel. heres a little chart for inlet runner length choose your cam timing (the pulse is created by the valve) and the length is in inches up the side very crude but a rough idea
basically the weight of the car is the reference takes x amount of torque to move x weight in a certain time, tach pulses give the time, find the weight (plus drive ratios etc) and it will pump out the torque. It works mint trust me but conditions have to be similar, same road no big winds etc but useful tool. Megasquirt is so aws because the code is open to anyone so all the good cunts out there can implement crazy ideas. Links hardware could do all the same shit as its more powerful just being out to make money they hold back shit for better versions etc
a light flywheel and good light wheels will more than make up for it. Think of the radius of a axle compared to a wheel its moment of inertia is fuck all
yea second set of injectors on top of throttles is worth a few hp but having the room to set is the problem. Megasquirt extra code has teh mean injector staging system. Also with resonance tuning your almost always going to be catching the second or third reflection theres no basic all aplication formula. Used this street dyno before which measures the time between spark pulses to tell if acceleration has been improved thus giving you a basic as dyno plot. works mean for seeing if trumpets or your tune change the power. Can give close to real world figures if you accurately put in the weight, drive ratios etc tis a mean tool seen guys dial in cam timing with it got it pretty bang on
um you can take a screenshot using the print screen key on your keyboard then paste it in paint or theres a save as bitmap options
Spencer's 1983 Toyota Corona Mark II SX60
Spencer replied to Spencer's topic in Projects and Build Ups
gave it a fresh matty b job for nats was finished the day before but came up sweet ( cheers to the guys who took pics at nats) Also after not realy liking 1gge's Ive ended up with two 1gges a 1ggze and a spare head.(the pics are a shambles) A filthy 1g sitting next to my 1jzgte another filthy 1g and a 1ggze with the spare head on it notice the hooge ports so theyve got some mad tvis stz ala 4age plans are to chuck a 1gge in it and drive it, and rebuild one of them with a planed head cams etc. Also picked up some more itb's I have a couple of megasquirts (diy engine management) sitting around so will chuck one on and go individual throttles. cad'd up some flanges and mike-e's getting them laser cut then a mate is going to weld them up so basically hoping to have a 1g in and running on itb's and megasquirt by next track day. which should be pretty easy as its all bolt up and I have all the parts -
hey bro the jzx struts fit sweet?
my mark 2 looks better without strips, but it doesnt have the groves for them so it has a much smoother look
^ think your confused there w57 was just the next box after the 55 with slightly different ratios (5th gear only) Ive seen them in celicas and cressidas with a range of shifter positions. there is a w56 and 9 that came behind diesels and vans
well dude with a 1jz has done 40,000kms in a 1500kg car with 240kws on an unknown condition box. some of the higher hp guys destroy them but jag = fine. Im doing a 6 throttle conversion just need to copy that * 2 haha but depends on your port spacing and angles so could be easy/hard. Start collecting those 20v throttles you'll need 4 sets as you cant use the end ones
your running a w5* aye? people run 200kw+ at the wheels through these no worries, I think you'll be fine
could be a good weekend for a couple of us hams cunts to come round, if im not doing any car shit that weekend
^ I agree with you there on some engines have quite decent cast manifolds but the 1uz ones are literally a log. Pretty sure theres dyno results on the soarer forums of pretty crappy extractors giving gains. Anyway havn't found those pics yet but will keep looking
Aren't they all real crappy logs?(think theres more than 3 if you count the real new stuff). Ive got a few pics of some in cressidas etc where its real tight will try and find them. Equal length is ideal but in reality anything is better than the stockers. Also 8 throttle bodies please
yea tonight was going to be a nah from me to still catching up on sleep from last week. but its booked in at my pad so im in
yea sweet edited as the image didnt work, its to soon from nats to organise a hard out otp but if anyone wants to drop in, mean
boes speaking of otps theres a few brews going down here tonight. You may remember this chap hes jetting overseas so cranking out a few brews/ air guitars[/img]
So you can bring me in some bits?
Hmmm yea intercooler is still desirable as compressing air generates heat tis basic thermodynamics. Crazy v8 setups still run intercoolers usually water/something colder sits under the super charger. I think an sc14 is a pretty asthmatic charger its runs out of puff pretty quick on a 1ggze. Also yea throttle after the blower = just run a couple of bov's to vent the pressure, seen a few 4agze's setup like this its stops the lag of the engine sucking up the air in the cooler piping when you throttle off. But gives you crazy throttle response with that boost waiting there basically pushing the butterfly open!!
haha mean boe the sanding was for that matty b job it had for nats. engine swap time now
Yea looking good dude, your in the same boat as me looks mean but would be insane with some more dish
booked out for the next few weeks got abit to sort out after crazy nats preparation
more spam in brads thread, but thats a silly statement a 40mm bike carb will pretty much flow the same as a 40mm throttle body of a 20v which only revs to 8000ish. its all a cost and convenience thing which way you go
^ yea boe take trailer anyway I'll probly blow my car up or something
