Spencer
Everything posted by Spencer
  1. im running tubes all round because a couple of my wheels didnt seal up after pulling them appart its mint. I think his problem was teh flipped rims not beading properly?
  2. Yea foam filters arnt shit just need to be cleaned and oiled alot more than a paper one. I mean if my old motor x bike ran a paper filter it would've sucked dirt for sure
  3. mean, so pwnt though didnt got to work until 12
  4. mean boe my pads such a dump and I just got a new flat mate, he is a grade A psycho like fully weird have to kick him out stz, but hes not here. Ive had a few but kerryn will pick you cunts up dont wanna leave a mint piece of machinery like a chevette out on the street
  5. ^ you cunts wanna leave the chevette there and get a lift?
  6. yea im not keen tonight got work tomorrow you guys seriously keen for tomorrow? If you are its sweet to have it here
  7. yup UZ is pretty smoth dont think you'd notice guy of garage doris mounts
  8. dude unless your fwd who runs a flexi joint??
  9. fuck just do whatever then work from there. Your trying to convert it so it sits on the newer style vertical mounts that later toyotas have aye? just seen most guys with that style go solid in the end when doing skids
  10. seen a JZ with a coin on top to smooth as fuck but still rips the mounts when doing skids. Edit: oh an unclejake its custom mounts to get th v8 in his soarer so there is no factory mounts realy but urethane mount would be the go
  11. because those ford ones are puss and skiddings hard on the mounts people rip those big ass toyota ones to bits, but sounds like your going the right was about it now
  12. I honestly think if your drifting this thing you'll fuck those ford mounts
  13. yea just got some for around $40 a pair from repco hookups. Toyota stz to big? I know people who have fucked the stock toyota rubbers skiding and there beefier than the ford ones. mk4 supra ones are the shit solid as but cost alot and probly to big
  14. the flipped sump worked fine got the engine in a nice place and aslong as your confident with your welding it should be mint
  15. rofls did you see the pic of his front disk shes already re drilled
  16. = you cant have them unless you register it as a 2 door (and cert it) which means removing seats and maybe welding up mounting points
  17. not an expert on this but the mk1 escort we had the sump was chopped and flipped so the bowl was at the rear. With the pickup turned around and extended worked mint
  18. you could ask mike-e but I think he may be busy with new job stz
  19. im probably busy but im sure one of the boys in hams could come for a drive?
  20. Spencer
    Ogre AMG 4g
    keeps the air velocity up
  21. Spencer
    Ogre AMG 4g
    100hp per litre can be hard/easy to obtain most of this will depend on the head got any pics of ports and combustion chambers? the best way to achieve your goal is to get the head cleaned up, bigger valves would be nice if possible, Itbs on a nice matched manifold, good headers, most compression you can go on 98 and then cam it to suit (all the na basics). If your motor flows well you will need less cam to get the desired hp figure and have a more useable engine ie. wont have to rev the tits off it
  22. If I had the parts I could easily draw it up in autocad then old mike-e etc could get it laser cut for fuck all
  23. sweet boes the box is off mykool im buying some shit off him so its under control for now
  24. the ones I posted are from t3 and are made for the silvertop throttle bodies 180us which is dear but I'd be happy to pay that as all the gear Ive got from them has been top notch http://www.technotoytuning.com
  25. hasnt txt or pm me but guess he hasnt been online but yea if he gets in touch I got it covered transit stz, then bring it to the swap meet or mongol can grab it
