Dell'orto
Everything posted by Dell'orto
  1. Guess all the prep work paid off! Gotta be happy with a 16
  2. Did wonder if they did it, or KLER. Colliers will did it properly at least, though there is a handy reconditioner just around the corner from you...
  3. Who's doing the motor? Not the same place that machined the head I hope!
  4. Fuck, that's shithouse re: head - salvagable I take it?
  5. Another +1 for Geartech. Not the cheapest option around (though not overly dear either) and they definitely know their shit
  6. The old man has a fancy stainless Bosch oven thing, and its crapped itself in various fashions 3 or 4 times in 4 years from new. He hates the damn thing, but the kitchen was designed for it so hard to replace
  7. God, how many other cool cars do you have casually stashed away? This is sweet
  8. A $20k gamble at that! Car is amazing though, I love 3 coupes so much, and this is done just so 90's NZ style, it rules my face clean off.
  9. So jealous. Love 26's
  10. I found out some years back, that those Arias pistons were meant to take a GSXR750 ring set, that was after B&H grooved them sadly. How did your end gaps turn out? When I stripped my motor down, the end gaps were massive (B&H gapped them etc) which is one of the reasons why I flagged the 4K
  11. They look much the same as yours - flat topped, 2 valve reliefs. I can't recall offhand what my combustion chamber volume was, but the motor was 11:1
  12. My block is zero decked, so you shouldn't lose compression. Give Graeme @ B&H a bell, he sorted the last lot
  13. FWIW, I also have a block to match the pistons, just needs rings
  14. If its only .010 over, I have a set of Arias forged pistons that would handle detonation/big revs well
  15. Never looked TBH, as there are usually plenty of 4AGEs on TM. Also if you don't like the Carib, why not get a Corolla BZ-T?
  16. Trouble with a 20v swap is they're all getting old and fucked now, and there are 20 valve stem seals to replace... Blacktop is way better, less reciprocating weight, more compression, bigger throttles, better flowing head. The only downside is that it has a gas tensioner set up instead of the spring loaded one, so cambelts are trickier to do
  17. This car pleases me
  18. Haha yeah I know what you mean, the wait can be frustrating! Especially for sweet convertible Impalas Not too much left to update sadly, the engine issue definitely left me demotivated! Cheers
  19. Haha thanks Ned...just trying to gee myself up to work on it again. Quite hard to be motivated now with it so far away, and so many other cars grabbing my attention!
  20. Discuss here: //oldschool.co.nz/index.php?/topic/43815-dellortos-ke70-sedan/
  21. February 2013fffffffuuuuuuuuuuuu Well - has been a pretty eventful couple of days! Car loaded up and ready to roll Went in and got a wheel alignment - was impressed, with the camber plates as the only form of adjustment it had just shy of 2.5 degrees negative camber! Had it set to 1.5 degrees, and stock castor for the time being. Made it intact to the workshop And thats where things started to go down hill... Even though I had booked in for a run up and tune, lots of other cars currently there were causing issues. Also my carbs needed a bit of tweaking (as I'd expected) and the dizzy was a tooth out too. First fire up went well, once the carbs were balanced - it sounds pretty amazing! Exhaust is quite quiet, but you can't hear it over the induction anyway Drove it around the block to go to the dyno entrance, and found it was dumping coolant all over the place :abusive: The lower radiator hose was too close to the alternator, and the fan chewed a hole through it. Shot down and grabbed a new hose and some more coolant, and threw it all back together. At this stage it was 5pm, so we ran out of time to do any tuning. Ran it up a few times on the dyno to give it some load, made a pretty reasonably 57kw at 6000rpm...it starts to go quite lean above 5000rpm so we didn't want to push it too much. It also has a pretty big flat spot around 3000, then comes on in a big way at 3500, about what I expected with this cam. Rodney, the workshop owner said once we get it tuned it should crack 70kw quite comfortably, and if it keeps making power over 7k then it may even touch 80kw, which I'd be pretty stoked with! From there, I went round to the cert mans workshop...sun was starting to set at this point He was pretty happy with the car, said if I want to lower the front more thats no issue Just need a driveshaft hoop, speedo calibration, nyloc nuts/lock washers on the diff flange and tighten the adjustable spring perches. With that out of the way, I began the mission home! With the T50, 4.1 diff and the smaller tyres, it sits at 3700 at 100k in 5th, so stays on cam. Between 4000 and the 5000rpm limit, it's actually pretty quick! It turns in quite well too, potentially to do with the diff. The spring rates are pretty well spot on, its firm without being ridiculously stiff, all the shocks are set at max soft, I think a bit of tweaking here will make it better over really ripply road surfaces. 10pm I got to BP in Otaki to top up the fuel - took a photo cause it looks pretty sweet under fluoro lights However that's about when it all went bad...went to leave, and no go. On cranking sounded like it had no compression...luckily some GCs went and got some tools and I started to pull it apart. Found that somehow the dowel that locates the camgear on the cam had come out, and had ground away the face of the cam :barfy: Managed to clean all the metal dust out of it, reinstall the timing gear and put it back together. However I must have cocked the timing marks up, as I couldnt get the dizzy timed up right, would either be too advanced or too retarded. At about 3am I gave up and called a tow truck, and had it taken home. So yeah - a few things to sort out, and I don't really have the budget or inclination to do anything about it. Pretty gutted to say the least!
  22. February 2013, pt2busy month this one! Yep... Filled it up with fuel tonight - 42 litres takes a damn long time to drain from fuel cans! Bonus, fuel gauge still works, albeit pretty slowly...was a bit concerned it might be dead after all these years of being empty. Light went out straight away though so at least I'll have some warning I was also impressed how quickly it got fuel to the carbs, given the Holley pumps are a push pump I was sort of expecting it to take a while to prime, but it was pretty near instant. Once I tightened up all the loose connections :shocked: this happened I'll have to get new washers for the carb fittings though, the ones I have are slightly too big, and they still weep a touch. Easy fix at least! Gave it its first wash in over a year! Ready to roll onto the trailer tomorrow. Also polished up the wiper arms, stainless steel comes up nicely! And dammit my exhaust is gonna scrape like a bitch on the road, it scraped coming out of the garage
  23. February 2013 Went with the angle tip in the end, the straight one was just too short, and the other ones were too long and looked stupid :barfy: So onto the final few jobs! *Bled up the brakes. Had an issue with the m/c being incorrectly assembled, figured it out and job's a goodun. Filled with Castol Response Super Dot 4, shouldn't boil too easily! *Filled the cooling system, found my pretty T bolt clamp on the water pump was too thick to fit properly between the alternator bracket and water pump outlet, so spilled a litre or so of coolant on the floor while I ran around looking for a normal clamp :Puzzled: Been 4 days so far with no leaks, so should be ok. Want to pressure test it before we go to Palmy though. It's not actually an antifreeze in there currently, just a non-glycol based inhibitor...was recommended not to use a glycol coolant with a new head gasket. *Replaced rear swaybar mount bushes..the ones the bar came with didn't actually fit in the mount for some reason? 100 series Corolla ones however fit quite nicely with 2mm trimmed off the flanges. So much grease Replaced the bumper and side indicator lenses, as the bumper ones were f@%ked, and the side ones were just old and faded. New vs old Got those new from Toyota some years back, front ones had to come from the Yahoo auctions - they're mint and cost me $13 Made up some rubber gaskets for the mirror bases today using an old inner tube...once they're mounted, all I need to do is fill it with fuel
  24. January 2013 Been super slack on updates with this - Christmas is never a good time to try and get this finished! Also, I bought myself an early xmas present Which both took up garage space and motivation However it's currently off at PPRE so I've got a few weeks to get all the last finicky bits done. Had no joy at all finding bumper end caps, so got a set from eBay. They're Thai replica crap of course, but needs must...with a bit of tweaking they actually fit alright. So slack I don't even have photos with the bumpers on the car! Also have a set of bumper indicator lenses coming from Japan, as one of them was broken, and had the wrong type of lens put on on it! Remade the rear section of the exhaust, as I wasn't quite happy with how the muffler sat....now it sits nice and tight, but I can't decide which tip to use...FWP I know:lol: Either the longer angled one or Thoughts? Also bled the rear brakes up last night - vacuum bleeder made it so much easier! Still took a bit to get fluid through, but given the system hasn't had fluid in it ever, I wasn't surprised. Quite nice to finally have all 3 pedals functioning as they should! Scarier still - dyno and cert booked for 20th of Feb
