Everything posted by 10Speed
yeah no more lifting the car over the engine... given how often you're pulling your engine out, I'm surprised you haven't done this...
continuing to do things in the wrong order... got sick of the tight confines of the engine bay, so took a leaf out of 63Ragtop's book and broke out my spot weld drill (and Dremel) and made the rear apron removable. Also uncovered a bunch of rust I'll have to tidy up... In hind sight this should have been the first modification I ever made to this car...
is that a Taipan?
http://www.weberperformance.com.au/product_info.php?cPath=59_276_277&products_id=1212 boost referenced by pass style... damn I might have to weld another fitting on my already powder coated tubing )-: might try with a tee first anyway...
intercooler, lol there's no intercooler on this rattly old thing sweet this makes sense, will tee off my fpr line, which is about 300mm from the compressor
I would like a sanity check on my turbo plumbing. Waste gate is plumbed to vacuum port on the carb Fuel Pressure Regulator is plumbed into the intake, just after the tee BOV, Boost Guage & Distrubutor (CB Magnaspark II) are plumbed in to a CB vacuum reference kit ( http://www.cbperformance.com/product-p/2040.htm ) pic of messy engine for reference
a Subaru TY754
- 497 replies
I'll see how you're placed when I have sourced a subi gearbox for mocking up
- 497 replies
fingers crossed I'd only need 30 mins or so to get the measurements I'm after... when are you pulling the body?
- 497 replies
if that beetle winds up as a bare pan at some point I wouldnt mind popping down to mock up a non-vw gear box I'm considering using on it one day... (or to help remove the body if you need a hand)
- 497 replies
you and me both, been a long 18 months
getting low now! any plans to pie cut the frame head?
- 497 replies
Well it's mobile again... Since I last drove it it has been converted to IRS, fitted a new gearbox, a new return fuel system, disk brakes on the front, bigger drums on the back a sway bar, special custom camber link pin bushes, and a new exhaust system. still not finished, still have a fuel leak to sort out, which is proving trick as it seems to only occur under boost. However the new box seems a lot stouter than the old and has survived a couple of runs under boost so far. Also sits higher in the back than I want, either have to cut the current spring plates or sort some dropped IRS plates...
- 66 replies
- 16
The Aliexpress Special, aka Raizer playing with scooters
10Speed replied to Raizer's topic in Two Wheels
I put a set of cases through the dishwasher once... ymmv -
one of my regrets was not making my rear valance removable... might still do it one day...
is that a 12v flywheel then?
- 497 replies
getting close, wait to have it on a dyno before any long drives...
Please tell me this is coming to OS drags in Dec
well it's been outside under it's own power...
today I found a piece of my very first VW for sale... this is the bonnet off my old Baja Bug, I havent seen it for over 20 years. One day I forgot to clip it down, and while heading along the nor-western, it flipped up into the wind screen and tore one of the hinges out. I replaced it with a spare I had, and can't remember how I disposed of it... The hinge is still broken and you can see remnants of the duct tape I used as a temporary get home repair... I nearly purchased it, but $5 seemed a little steep... (posted in this thread, as it's kind of the genesis of this project)
apparently it is a built beetle box
- 497 replies
yeah soooo strong pretty sure that was a built box, even though they didnt focus on it much... but 12's out of 200kw is pretty cool
- 497 replies
what was the source of the leak?
- 497 replies
http://www.steeringboxscrapers.net/low/index.php?topic=7812.0
http://www.trademe.co.nz/a.aspx?id=936537879 future classic? (probably actually)
