SloNLo
Everything posted by SloNLo
  1. Finally got a new car destined to be daily transport with a few mods 5k 1500, 4 speed column change lots and lots of K's on it but the panels are surprisingly s]traight even has a set of builders roof racks. plans 14 inch trident mags dropped 2 or 3 inches, torsion bars wound down in the front and blocks in the back. some kind of stripe down the side- will photoshop some options up soon. a nudge bar for the front. i don't want my legs disappearing if i hit something. interior cleaned up. and get it running properly. trade me photos was completely gutless when i picked it up checked and regapped he plugs checked timing and found it was retarded 5 degrees, what the hell? set it to the proper 10 degrees and wow it actually feels like its got some guts now. hooked up a second earth cable to the block and it kicks over much better now, no more "will it start?" moments, i hope. has some bearing noise in the gearbox so i have drained and changed the oil, hope it quietens it down a little. gave the paint a good cut and its almost shiny now need to get a stereo and a speaker or two hooked up for some driving tunes will get some more photos up soon
  2. should give it the idea i think
  3. 2T Engine Specified Parts Tightening Torque Crankshaft bearing cap to cylinder block => 7.2 - 8.8 m-kg (52.1 - 63.7 ft-lb) Connecting rod cap to connecting rod => 4.0 - 5.0 m-kg (28.9 - 36.3 ft-lb) Camshaft thrust plate to cylinder head => 1.0 - 1.6 m-kg (7.2 - 11.6 ft-lb) Timing chain cover to cylinder block => 1.0 - 1.6 m-kg (7.2 - 11.6 ft-lb) Oil pump to cylinder block => 1.7 - 2.6 m-kg (12.3 - 18.8 ft-lb) Chain tensioner union bolt to cylinder block (2T-G) => 1.0 -1.6 m-kg (7.2 - 11.6 ft-lb) Crankshaft puller to crankshaft => 4.0 - 6.0 m-kg (28.9 - 43.4 ft-lb) Cylinder head to cylinder block => 7.2 - 8.8 m-kg (52.1 - 63.7 ft-lb) Camshaft timing gear to camshaft => 7.0 - 11.0 m-kg (50.6 -79.6 ft-lb) Valve rocker support to cylinder head => 7.2 - 8.8 m-kg (52.1 - 63.7 lb-ft) Manifold to cylinder head => 1.0 - 1.6 m-kg (7.2 - 11.6 ft-lb) Cylinder head cover to cylinder head => 0.4 - 0.7 m-kg (2.9 - 5.1 ft-lb) Oil pan to cylinder block => 0.5 - 0.8 m-kg (3.6 - 5.8 ft-lb) Oil pan drain plug to oil pan => 3.0 - 4.0 m-kg (21.7 - 28.9 ft-lb) Spark plug to cylinder head => 1.5 - 2.1 m-kg (10.9 - 15.2 ft-lb) Flywheel to crankshaft => 5.8 - 6.6 m-kg (42.0 - 47.7 ft-lb) Flywheel to crankshaft (2T-G) => 7.7 - 8.3 m-kg (55.7 - 60.0 ft-lb) Clutch cover to flywheel => 1.5 - 2.0 m-kg (10.9 - 14.5 ft-lb) Clutch housing to cylinder block => 4.8 - 6.8 m-kg (34.7 - 49.2 ft-lb)
  4. so your saying if you dont want to bust your nut loose inside her seat go slow and make sure to lube it up first
  5. i give you the commer compact .... haha loving the wheel base
  6. nope its spacing the topout spacer up the shaft. total lengh of the shaft is unchanged in this pic the dark gray spacer slides of the shaft the the left then the red spacer can be slid off followed by the white the steel braket left is attached to the shaft and dosnt move here is a comparison to make things clearer each shock showen bottemed out and full extention it shows that the spacered shock will bottem out just like a factory one will but will hold a shorter spring captive the shortened shock will hold the same spring as the spacered shock captive without botteming out as easily hope that makes sence
  7. you havent earthed it to the chassis have you?
  8. ive got a good looking 1300 carb here if your keen
  9. im building a morris minor with escort running gear so if i cant find an escort body to chop up for mounting point i may have to make some
  10. both would be good is possable
  11. is someone could messure a few things that would be great what is the bolt spacing on escort front strut tops and the distance between centers of front struts(accros engine bay also the hight from center of wheel to strut top(factory or lowered as long as you know how much its lowered by) thanks
