Lord Gruntfuttock
  1. It worked. Discovered my dusty old practice amp is an Ashton too... It made noise, and the tuner worked, if a little rudimentary... But the action needed sorting, and I wasn't happy with the flimsy screws into plastic holding the unit to the body. There's a bit of extra tension with the bendy surround mod, so I drilled out and used 3mm black machine screws. Much more secure... The new nut was way too high, so pulled it and sanded similarly to the saddle, supposed to have roughly 1/2mm clearance at the first fret. Before/after pics... And all done, re-strung and whole thing looks much better, and seems playable, now just down to the operator...
  2. ^ That's pretty wood... Guitar renovation 2, parts arrived. Installing where the existing tuner hole was meant it wasn't in the flattest part of the body, so I disassembeled the EQ unit to get the faceplate off, and bent it up after softening in hot water to get the required 'S' shape... And the combined connector/strap button needed installed. I wasn't happy with the exposed wiring so added a bit of heat shrink... Then just fished the wires through, the connector and a braided piezo pickup you install under the saddle, through a 2.5mm hole near the bass string. This means the saddle must be trimmed around 2mm, I just sanded this down on a flat surface. It's definitely real bone... Then threw some old strings on to check operation...
  3. I've got a Spice girls sticker on my old one...
  4. Guitar renovation. Last century I used to play a bit, completely hopeless now but wanting to try again I attempted to set up my crappy old acoustic properly, got all enthusiastic and shouted it a new bridge, saddle etc but the truss rod thread stripped just as I was getting it right, so I swore a bit - and have been looking out for a decent'ish used one since. Saw this advertised at a charity shop, Ashton D25, scratched, rusty, 2 strings so grabbed it as a cheap project... [Reviews state the D25 is a 'cheap, nice sounding full-sized beginner/muckaround guitar' so perfect for my needs] I re-strung it to check things and apart from needing some new parts it actually played OK, neck was straight, strings at good playing height etc, so I ordered a bunch of bits from Aliexpress, then stripped it right down and gave it a good clean. Can't do much about the giant scratch on the body but might try to hide it later... The Ali machine heads fitted perfectly, sort of wished I'd got the black option now though for full blackout look, but they look far better than the grotty old ones... And the new bone nut and saddle looked to be well made. The plastic ones were worn out, (nut had actually crumbled at the 6th string and I'd filed a temporary notch to test it) also got some fancy bridge pins... Biggest issue was the cheap in-built tuner, that was missing the battery holder clip. I bodged it up and it still worked but the cover/clips are always going missing and are unobtainable, so bought a combined tuner/equalizer/pickup unit to turn it into an electro-acoustic... This is still on the way, so I gambled that the online templates will match what I actually get, and cut the hole while I had it apart... Hopefully this arrives in the next few days and I can see how things go together, bit of wiring/fettling to do when I get it. It won't be fancy, but I should have a useable geetar for around $100 all up...
  5. Assume the purple HD pro is this stuff from the SG website? Struggling to find it in NZ, the only purple stuff seems to be antibacterial. Any clues as to where to get it @tortron? If too hard I'll just carry on with normal simple green and/or dishwashing detergent...
  6. I bought a 6.5 litre one off Ali, sized to fit bike carbs, love using it. I did wonder about just buying transducers and making my own up from a suitably sized stainless bath/basket setup. Wouldn't be hard to do...
  7. How satisfying is seeing the initial cloud of gunge come off something though...?
  8. That's a pretty boat...
  9. Perfect OS vehicle...
  10. Might come with bonus scorpions...
  11. Better pic yeaterday in sun. But reposititioned after watching birds landing preferences...
  12. In poorly-made things out of scrap, knocked up a nectar feeder for the local birbs. Seems to work...
  13. Yeah man just get it going. Carbs are sweet to play with. Maybe electronic ignition but that's all I'd throw at it modernising-wise...
  14. Cool. Great idea putting a project thread up, really good way to keep track of progress and get advice/encouragement. Look fwd to seeing it come back to life...
  15. Ah maybe cos I'm on tank water it goes ok, had it tested for brewing and it's near as dammit distilled water quality...
  16. Oh interesting. I've done a few carbs in simple green and only ever had one go a little like that. I dilute and rinse off immediately though. Will investigate the SG purple. Didn't even know that was a thing...
  17. I've just used disposable plastic shot glasses to scoop out small amounts of paint/hardener in the past. Toss 'em when done. When house painting I've just bought a soup ladle from the $2 shop. Mainly cos I can't pour paint without making a mess, means the lid grooves stay clean etc...
  18. Saw this today at a car show. No idea what's in it tho...
  19. Yeah that's frustrating as hell. Mate had wooden dash pulled out of his Mk1 Jag in his garage, (effectively writing it off). They left pliers etc in car but no prints taken, even with a good idea who it was. Bring back horse thief punishment I say...
  20. How bout this one...? https://www.facebook.com/share/hPXjrLTapMHExDWA/?mibextid=kL3p88
  21. Yeah couple of Windsor plugs can be a bit awkward, can't remember which one, but one of mine is only accessible with the right combination of socket extension/universal joint attachments. Typically they're the plugs that never get changed or get cross-threaded by booger-fingered owners...
  22. ^ My Mini build brings all the Barrys to the yard, and they're like, worse sharns than yours. Damn right, they're worse than yours. I can teach you, but I have to charge...
  23. They're a strong tranny. My only failure was when the torque converter fins fell off and I lost drive (burnouts to blame prob). Still running same trans but I've put alloy sump and thick silicone gasket on after suffering leaks and have replaced the filter, lower pickup too with deeper sump). There were a few flakes in the sump but I've chosen to ignore them...
  24. How's the fluid. Checked level on dipstick with engine warm and in park? Colour? Burnt smell? [Edit] sorry just read properly. If fluid looks good I've got nothing...
