Liath
New Members
    Auckland
952 profile views
Liath's Achievements
Member
Member (2/5)
14
  1. Try eBay, workmate just got a nos ex Egypt
  2. Hi Geoff I found www.lextreme.com to be the most comprehensive resource for all things 1UZ, especially wiring pin outs - the search function on that site will e your best friend.
  3. Hi, I would be keen in the Pukekohe/Tuakau area - have a semi project car(goes just needs work all the time) and a spare parts car I would like to store undercover and work on undercover..
  4. Fwiw I have a 1uz with M112 on top, have a custom bronze/copper radiator 650w X 60d X 450h -a single 400 dia fan pulling air when needed. It sits around a 1/3 on the gauge while moving however even idling at the lights takes it quite quickly past the 3/4 mark to just below panic stations - start any sort of forward movement and itis back into "normal" mode. Motor has about 100k on it, 20k with the blower and has done the heat up while idling from day one - the motor it replaced had around 40 k with the blower on top (120 all up) and did not do this - have never got to the bottom of why. I have had the motor in and out a few times due to foolishness and have never had an airlock in the cooling system. Have driven around with blower disconnected after I left the accessories belt behind and it did the same thing. Have replaced the water pump - no difference. I just try not to look at the gauge while stuck in traffic now...
