Everything posted by Mof
@Willdat?did mangles valley/braeburn yesterday. Tutaki rd freshly graded marbles and dusty as fuck. Braeburn Awesome! Can't wait for that. Porika this morning. They logging the st arnaud end but the track is still clear.
Have we got a entered/ paid list somewhere?
Is there any advantage of being classed MC rather than MA?
Also, while I've got you here, if your sisters truck is a slide off camper on a flat deck, is it registered as motorhome or commercial vehicle? Difference in rego cost?
Thanks for making me look this up though, it must have changed recently-ish. I think it used to be gvm 6000kg but loaded under 4500kg
Maximum glw or gcw of 6000kg, doesn't matter how much it's loaded
@Pee Dubs did you get some new tyres yet?
Kodiak and deemaxx are still available. Tip out the oil and grease them.
I think you would find the springs will find a way to be above the equaliser, probably with a bang. If the axles were underslung and the springs above equaliser, what is the ride height then? If the braked axle was underslung, spin it around (left side becomes right side) then your brake brackets should be back to the same position. (Edit; looks like you already did this) The front spring shackle looks like it would go up inside the crossmember?
Isn't it a no impact, no abs therefore no compliance type deal?
Just looking at maps, French pass looks like a lot of exposed Ridgeline? And kenepuru is following the coast in the bush? What's the road surface consist of for those two?
It's 17 mins from your motel If we're not in too late or too shattered I'd be keen to hit up that beer garden restaurant again.
He wants to go right now too
Recommend Maitai valley camp in Nelson, and Rarangi doc camp Blenheim for tenting. That's where I'll be. And probably one of the vehicles too. @governorsam @joshcburgess
*Cherylea motel
Butchers flat
Double eye rockers are far far better than that slipper junk
It's on the back of the trans, probably oil in it
1st Jan 1990 https://vehicleinspection.nzta.govt.nz/virms/in-service-wof-and-cof/general/lighting/high-mounted-stop-lamps Mine is 1993 and has never had one
Wat it's none of those things I can still read it
Hey what does your rear spring slipper look like? I don't suppose the trailer might have once had a double eye rocker type? That might explain the long rocker bracket.
Doesn't look like it should to me. It won't go far with an input shaft thru the middle, and a pressure plate up against it
https://www.tapatalk.com/groups/aus80/tapping-knocking-noise-in-my-1hz-t10937.html https://www.certifiedautomotive.com.au/toyota-landcruiser-1hz-cracked-head/?amp=1
