Everything posted by Muncie
Used to work for Rocket lab, yup i know who you mean. Rocketlab didn't fit in with my "work life balance" goals at 38 i was considered fucking old.
Yeah i picked up on his involvement through his build threads. Oldschool.co.nz seems to be the "Google" for car knowledge these days.
Signed up for a hpacademy wiring course will see how well that holds my attention after sitting through 9 hours of zoom meetings today.
I want to build nice compact looms that can maybe be tucked away a bit easier than a stock one without old crispy connections. Ive always managed to get stuff working but yeah no more bullet terminals time to up the quality and water resistance. Working for Rocketlab spoiled me.....
Ive got 1 big loom to built for my Commodore engine harness and 2 motorcycle looms to make up very shortly whats the go these days? Wanting a nice wrap that isn't that split corrugated junk. Wiring wise im open to some non mil spec connectors but reasonably priced and availability for less than a limb for my motorcycle looms and maybe ignition harness on the commy. What have you found or recommend tools supplies consumables etc youtube videos even?? Im not going into business im just sick of ugly wiring on my projects, i do have kids coming into building projects so might as well teach them to do shit nicely.
Daves new school holden shambles. (And finally a Turbo)
So with the ecotecs health now down graded to running but may become terminal soon, I started on stripping everything that wont be going in with the engine swap off the L67. Including one rather haggard in places engine loom. Just exhaust manifolds to go and thats as far as it'll need to go.- 353 replies
- not as good as a barra
- ecoboost
(and 1 more)
Tagged with:
Threw new O2 sensors in today runs nice and idles better took all of 10 minutes to do both fuck it was easy! Why ive not done them before now escapes me thought it'd be a bitch of a job. Also threw in another cam sync sensor cos the one on my new engine was visibly newer for good measure. Think ive got a theory on the crank sensor fault, may not actually be the sensor ive got 2-3 mm of float on the crank when you go to start it the starter pushes crank forward. And at low revs just the tips of the reluctor ring pass through the sensor giving a shit signal. Give the crank a nudge back and the idle improves if its pushed forward so it might just be that.- 353 replies
- ecoboost
(and 1 more)
Tagged with:
Blowtorch that shit sweeping motion with a wide torch nozzle works a treat not aiming to melt anything just freshen up surface.
Some new parts from Rockautoparts.com and some new sensors from @vk327 Should get things back on track, Will look into setting up a Wideband when i redo the exhaust soon so i can do some proper tuning once i get the new engine in.- 353 replies
- ecoboost
(and 1 more)
Tagged with:
Went to go get milk and bread on Saturday and it died all of 200m from my home, another bloody crank angle sensor issue for sure ecu shows no rpm when cranking mindful it could be a broken wire or something. So to rule out the sensor im chuckin yet another new one at it, doing new o2 sensors as well so everything is fresh for when the l67 goes in. On scrounge for some headers if anyone knows of any???? Will be going twin 3" into single 3.5" with resonators into a Flowmaster 44 series will probably put a truck muffler at the end to knock the noise right down. Have already started hoarding parts as money allows. Decided to go single incase i go turbo later on saves a bit of fab work and parts too. Should sound pretty mellow and flow all it puff out, after all im getting older and cant be fucked with a droning exhaust.- 353 replies
- ecoboost
(and 1 more)
Tagged with:
@vk327 Hey mate have a squizz at this currently running this modified code in my spare ecu runs better than stock, i have a few tunes to kick things off with hence im willing to give the flash ecu a go. If it doesn't work.... well i might have a wiring loom job for you or will go manual and chuck a decent aftermarket ecu in it.- 353 replies
- ecoboost
(and 1 more)
Tagged with:
I'll pop harmonic balancer off and see what its up to and if its indeed eating sensors it didn't seem to to have made contact. I need to replace o2 sensors have logged them theyre poked probably original new engine doesn't have any on it. Have replaced the DFI with new one so far is behaving. Curious why you recommend the upgraded pre flash ecu over the later type? Noob question but if anyone knows it'll be the guy who works with them frequently.- 353 replies
- ecoboost
(and 1 more)
Tagged with:
Can anyone tell me about their experiences with Haltec ECU'S? I want to retain the factory one for transmission duties only and get a standalone unit to run the engine and ignition, and also allow me to run a better crank trigger.- 353 replies
- ecoboost
(and 1 more)
Tagged with:
First day at new job she started randomly dying full engine shut down no sputtering rev counter straight to zero fortunately i was only going to pick up my work ute. Suspect ive killed another crank angle sensor (number 3 its deaded) though could be an ignition module i have new one so will try that first. Im going to have think about improving this with new engine getting to be pain in ass.- 353 replies
- ecoboost
(and 1 more)
Tagged with:
Muncie replied to h4nd's topic in Other Projects
Before anyone freaks out yes its a expensive norbar wrench but its been on production line for a few years and would no longer hold a calibration this was the perfect retirement for it. -
Built this for an old workmate who absolutely is the epitome of "everything is a hammer" so much so all torque wrenches got referred to as torque hammers on site. It still functions and will dampen shock if you adjust it down , pretty cool kind of dont want to give it to him.- 1292 replies
- 29
Stu's 4agte 85 EP71 Starlet and 4age 84 AE86 Levin
Muncie replied to Stu's topic in Project Discussion
Liking the "Billet Timber" coil cover you could be onto a trend there if you get some clear coat on it. -
Something has happened. Ive combined this with my sons now retired motorized mobility scooter as he just got to tall for it but it had a very stout chassis. Quad front is welded on seat will be dropped down heaps and moved back, axle placement will settle where it functions best and gives enough leg room. Robin engine will go on to work out kinks but vtwin is been sat in as i go so it fits for when im happy its all going to work.
Grind all the paint off....... rust is lighter than carbon fibre.
Haha "its an elaborate solution to a problem that never existed" Its the one thing that i can always fuck with and get instant results for fuckall money. Its actually bloody sweet to ride now though i would like to drop some scooter body panels over it too hide all the shit going on.
Could you use a centrifugal blower or even a roots supercharger and spin it with a briggs or something? Even a small one should move plenty of air for a single cylinder.
Section 6 if you still need any clarification, buy a .5 meter 1 ton roundsling from Cookes and 2x rated bow shackes 2+ ton so they arent too dinky. Should serve you well for decades.
On my supercharged vx i scored a full Remus system basically the same pipework as an HSV System but has a single twin in twin out middle muffler that tucked well up in the tunnel. The rear muffler was also twin in twin out with slip joints it sounded awesome with the back muffler off dumped at diff but was a bit to loud. The whole system though was quiet (for a performance system) had a real deep mettalic sound to it obviously flowed well. Tempted to replicate the remus system with a bigger middle muffler and v banded big muffler at back so it flows well and is quiet but can drop the back off for noise and max flow without it been too loud, these things shriek with the boost wound up!- 353 replies
- ecoboost
(and 1 more)
Tagged with:
Secured a job with a company vehicle so can afford to get stuck into this and have it off the road soon. Current plan is to pull loom off l67 and track down a stock vy ecotec loom and extend the required connections injectors throttle body etc, maybe fit some new plugs if they are crunchy. I want to get a intercooler plate under the blower before it goes in as well they are $1500 so will need to find that first, this alone should give a 50kw gain over stock. Tossing up between a stock twin HSV v8 exhaust, and building a 3.5" single system unsure if i want some noise or dead quiet the supercharged engines actually sound alright but i do like the idea of a sleeper.- 353 replies
- ecoboost
(and 1 more)
Tagged with:
