Everything posted by kws
Kelvin's 1985 Rover SD1 Vanden Plas EFI with Speedweeeeeeno
kws replied to kws's topic in Projects and Build Ups
Took the Rover out for a Rove today, its driving really well, with only minor hiccups every now and then. Still some ironing out to do in the tune. On the other hand, i filled up today. Spotted this in the owners manual and had a lol Clearly BLMC had some sense of humor back then.- 91 replies
- reliabletransport
- sd1
(and 1 more)
Tagged with:
Did some more work on my tune, and fixed a couple of issues. http://www.tasteslikepetrol.net/2017/03/speeduino-rover-sd1-quirky-tuning/- 91 replies
- reliabletransport
- sd1
(and 1 more)
Tagged with:
hahaha, those battery "terminals" are amazing. Sounds like progress is happening quickly.
My Rover is old school as fuck, it just runs a big resistor on the power feed to the pump, to drop the voltage. Its factory like that, and apparently to reduce noise, lol.
I would have thought this would be he best way to run it. Return to tank, and a separate overflow back the tank. *not my image, but makes sense. Hot fuel goes back to tank and doesnt go anywhere near surge.
In other news, i made a quick enquiry on the Uk Rover SD1 forum about how i could find more info of my car from its couple of years in the UK before it was imported. This is what one of the members came back with. Now im going to contact the UK DVLA as apparently they can provide details on previous owners. Would be awesome to know where it was originally sold, and to whom. Ill be looking at making some display plates up of the original rego too, just for the hell of it.- 91 replies
- reliabletransport
- sd1
(and 1 more)
Tagged with:
Did some cruising today, what a bloody stunning day it was too. Went and helped a fellow Rover club member with his SD1. Unfortunately it looks like his ECU may have issues, will have to do some more digging and make a plan of action. Mine is running bloody spot on, still some work to be done on the acceleration enrichment though, it just seems to be a constant sore point where i cant seem to get it right. At the moment it would cruise great but when you gave it a whack of throttle it would bog slightly and blow a puff of black smoke. It goes very rich for a split second in the logs. Im going to try disabling AE and see what it drives like then, and maybe slowly add it in bit by bit if it needs it. I have done about 150km since i started tuning, and about 1/4 a tank of gas used.- 91 replies
- reliabletransport
- sd1
(and 1 more)
Tagged with:
Speeduino can do upto 4 cylinder sequential, but im running it in batch mode
A quick update for today http://www.tasteslikepetrol.net/2017/03/speeduino-rover-sd1-a-gas-stations-best-friend/ She's thirsty!- 91 replies
- reliabletransport
- sd1
(and 1 more)
Tagged with:
Took Rover for a decent drive, and did some tuning. http://www.tasteslikepetrol.net/2017/03/speeduino-rover-sd1-basic-tuning/- 91 replies
- reliabletransport
- sd1
(and 1 more)
Tagged with:
Not for a long time. Theres some really good stuff on that site, Will have a read of the tuning stuff. Also currently having a good read of the megasquirt manual tuning guides. Its amazing just how much fuel this engine needs, its bit of a thirsty dinosaur. Plan is to get the map as solid as possible, on the rich side, and then use VEAL to auto tune it down to cleaner running.
Progress. Car now runs and kinda drives. Four weeks to the day since i took it off the road. http://www.tasteslikepetrol.net/2017/03/speeduino-rover-sd1-four-weeks/- 91 replies
- 5
- reliabletransport
- sd1
(and 1 more)
Tagged with:
If you have no luck in akl, i'd give coastal fasteners down here a call, http://www.coastalfasteners.co.nz/
Heard from the previous owner, apparently the restrictor plate in the exhaust was removed a couple of years ago. Ill still check just in case. Shame I can prove the myth myself, but it sounds like this one was restricted by Suzuki NZ.
Reconditioned the carb today. Sure enough, the pilot jet was the culprit. Completely blocked. http://www.tasteslikepetrol.net/2017/03/scooty-puff-jr-its-alive/
I dropped my horrible one piece exhaust yesterday so i can fit the wideband http://www.tasteslikepetrol.net/2017/03/speeduino-rover-sd1-dropping-the-exhaust/- 91 replies
- reliabletransport
- sd1
(and 1 more)
Tagged with:
I picked this up yesterday, a 2007 Suzuki SJ50QT. At the moment its a non-runner, mostly, and smokes like buggery. It had the wrong oil in it, and there appears to be some issues with the carb and not supplying enough fuel. Should be some fun when i get it running. http://www.tasteslikepetrol.net/2017/03/scooty-puff-jr-welcome-home/ It also has this interesting little tag....
I did some more work on the car this evening. Radiator is back in, as is the modified intake. http://www.tasteslikepetrol.net/2017/03/speeduino-rover-sd1-more-coolant-on-the-ground/- 91 replies
- reliabletransport
- sd1
(and 1 more)
Tagged with:
I was really hoping to get a couple of tanks of gas on the old setup so i could compare, but i just ran out of time to go through 120 odd liters of gas. It cant be worse than the Lucas tune, surely.
Woah, whats this, an update?! Much progress has been made. http://www.tasteslikepetrol.net/2017/02/speeduino-rover-sd1-a-rather-large-update/- 91 replies
- 6
- reliabletransport
- sd1
(and 1 more)
Tagged with:
LSD in FWD is common on higher performance models. All Type Rs had then for instance. Hell, my subbie has an LSD front and rear, and a viscous coupling in the center.
Haha, so many feels for having a British car thats been "barried". Looks good, i like the minilite style wheels on it. Will follow.
haha yes, those little bastards will cut deep if you dont!
Didnt have one on hand tbh. The wire will be sleeved, and will have a section of corrugated tubing on that section and then firmly ziptied to the bracket. I can change it at a later date if needed. That bolts a fun one though as its into a coolant gallery and when you remove it a nice jet of coolant shoots out.
