Everything posted by Benno
J.e.d.'s 1963 Ford Galaxie Hardtop Discussion
Benno replied to The Bronze's topic in Project Discussion
Fuck I love this car, got some photos of interior and engine? -
So its still on Sunday as usual then?
How many OS members are there in Dunedin?
I too could be quite interested in this. What would the go be on doing some minor work to the car? Would the car being non-drivable be an issue?
It is the yellow/black wire
I liked the idea of grey, so decided to go with a metallic gunmetal grey. Keen to get into pulling off the tank and painting it, but don't really like the idea of having to walk to uni again so might have to wait.
A more simple hardware solution might be to use something along the lines of what Simon suggested, perhaps an Arduino. With a built in voltage regulator and USB programming capabilities the only hardware required would be a voltage regulator for the servo, a voltage divider for the input signal and a couple of switches and LEDs. Any software changes could be made in minutes with any laptop with a USB port. KK - adding a potentiometer/rheostat to adjust the gains would be very simple to add to the code. Also happy to help out with code or schematics if you want to have a crack at it yourself
Looking pretty good man. How stable is the PI control? Does the servo oscillate much?
Another option for colour or red
Got a bit of work done on the A50. So far I have fitted drag bars, removed indicators, added a rear light and cleaned and painted the exhaust. Next step is to get the dent out of the tank and get the paint sorted, followed by sorting out a slim seat. Still not decided on what colour to do it, tossing up between matt army green or a gloss dark blue or something. Been dailying it and it's been running like a dream.
Haha, I was wondering who that was. Yeah, it seems to smoke a bit when it is cold, seems to go away when it warms up though. Hopefully isn't going to end up being an issue
What fuel ratio would I be best to run in the ma50? Doesn't say in what little I have of the manual. Would 32:1 be safe enough?
I was feeling bored so had a go at photoshopping up some ideas for the A50. Thinking that something along the lines of this with some drag bars and a sweet seat might look alright. Planning on dailying the a50 so probably won't actually get around to doing anything major on it until the ma50 is working. Ideas/suggestions/abuse?
Progress on this is temporarily suspended as I have got myself a new toy to play with. Scored this for free off a relative. Bit of work and it seems to be running like a charm. Went down and got new plates for it today. After taking it for a ride I was amazed at how much power there was for a 50cc engine, after some investigation turns out it actually has an 80cc engine. Hopefully no-one ever looks closely enough at it for it to be an issue, engines look identical. Plans are to get this tuned up and running nicely and keep fairly stock while I work on making the ma50 wild, then once thats running turn my attention back to this. Might be tempted to repaint the tank and acquire some sweet drag bars and a nicer seat for it in the mean time, will see how things go.
Coming along nicely. What have you decided to end up doing about the driveshaft loop issue?
How much flooding are we talking about? I discovered today the escort doesn't really like flooded roads much haha
That manifold is looking awesome mate! You just going to run the vacuum off a single runner?
Taitapu would be pretty mint
Took it for a quick test ride today. Pretty sketchy on wet ground with no brakes, so didn't give it too much of a thrash. Something seems to be loose in the front suspension, it wobbles around a lot which doesn't help either. Points still fucked and needs a bit of a tune, otherwise it seems to be running well. The clutch cable is still quite sticky and takes a while to release, I'll keep trying to free it up or replace it. Need to investigate this battery charging system next, have ordered a cheap shitty rectifier/regulator from ebay.
Finally got it running today Went through checking and testing everything. Got around to removing the coil, gave it a clean up and turns out it's a 12v coil. No wonder it didn't work with a 6v battery. Hooked up a 12v car battery with a 'whats the worst that can happen' attitude, immediately starts making a fat blue spark. Put spark plug back in and started second kick. Didn't run too badly really, needs a bit of a tune up though. Hopefully new points won't be too far off. Will get a 12v motorbike battery next week, sort out some brakes and hopefully take it for a run. Anyone in the Christchurch region got a front brake lever and cable they want to sell me? What fuel ratio should I be running? Currently put some 20:1 in there as figured best to be cautious and a bit smokey, but this is probably a bit excessive.
Guypie: That would be awesome mate, appreciate it a lot
Yeah, I came to the same conclusion. Apparently there is a guy up north that has a manual, but is a dickhead and wants ridiculous amounts of money for a scan. Once I get it going I'll investigate things with a multimeter, then make a regulator and rewire it from scratch. Wiring is a mess anyway. Shouldn't be too hard. With a little luck those new points will show up in the next few days
