Everything posted by SOHC
Try Malcom at econohonda
I had to get a pair for a yamaha xt600 and the genuine ones were over $300 for a pair, i got aliexpress ones for $12 a pair and they are fine, At the time I could not get anything for my SOHC 750 and when i got NOS ones ther were hard, That little lip they have on the inside that sits into the grove on the carb is realy important and i think why normal hose didnt work,
Proprietary shaped honda things, i tried runbber hose on my cb900 and it didnt work, they have to be perfect of they leak,
I tried with a solvent once but they expanded 3 times the normal size, silicon will work for a bit, use to do it all the time at the bikeshop when this old stuff was on the road on its last leags
I meen if one cylinder is burning the paint off 1st and getting hotter, Rubbers may look mint but if they are even remotely hard they leak,
#3 with paint burnt off will be an air leek somewhere I garentee
My 400 four and 550 all were funny on #4, and smoked constantly out the exhaust,i got a spair 400 engine and #4 was full of carbon on #4, i think its from people letting them idol on the side stand and it starves that side of the engine.
Seat is all mounted with new brackets at the front, spent most of the day on the front wheel, I had to grind down all the spoke niplels and give the spoke holes in the rim a little grind as that rim is drilled for another hub, i highly recommend using the correctly drilled rim unless you want to waste time. When lockdown finishes i amm off to the brittish bike parts library where i can exchange stuff for more parts
Moryes do a compressor oil
Save a shit load of money to
Just spoke to Trevor Hall and he reckons replace that whole bearing with a bronze bush, lots of bikes ran bushes for main bearings. If i got rid of the inner bearing completely and drilled a hole in the bronze or cut a slot for the big end oil feed would work
I will look into it but everyone has sed dont do it, the big end is oiled thrugh this bearing, the oil is fed into the needed roller main then the bearing extends into the crank slinger, i cant put a sleeve on the shaft because of this, i cant find an INA bearing even close, a ball race bearing cannot be used because of the oiling system. They did make O/S rollers but i cannot find anything and the shaft pitting is too deep
Pipe it into the ait filter
With a pump you dont have to, just blow them into the air
Some people use a vacuum pump
Shaft is 19mm and i cant take any more off it, if the sleeve was 1mm thick it would roll it up and blow the motor up, I have had gearbox shafts hard chromed and ground but they didnt have bearings running directly on the surface. The bond of the chrome is not stroung enough
I made one in the end from a $9 garden sprayer with the pressure relief valve tied shut with wire, was putting out 90 PSI
I got the races out of the caces very carefully as i want to re use them, cant chrome the shaft as the rollers run directly on it
Still looking for a set of 37mm honda CB froks or something, Finding someone to make that main shaft is proving to be difficult to
There is some trick where you grind a bit off the valve stems on the 5 HP because of the easy pull start system keeps the valve open untill just befor TDC, and if you set the tappits at the point its on that ramp on the cam it boosts compression a bit
He’s 5/8 tall? You could keep him in a match box
Where can I buy 5/8 UNC studs?
It was me, hot glue works well but you need to use a hot knife to get it flat and tonbond better
It had a really nice wire feeder but I would say you would struggle to weld anything at all even panel steel or an exhaust
