josh t Posted December 20, 2024 Posted December 20, 2024 Okay he's problem I have just done exhaust gasket car was running before I done it and now it is not running have done plugs distributor cap distributor have fuel running to it but will not start any ideas car location Hamilton Quote
mjrstar Posted December 20, 2024 Posted December 20, 2024 Cranks but won't start? Did you replace the rotor in the distributor, and did you confirm that the centre sprung loaded contact in the cap hasn't fallen out. Aldo double check your leads are on correctly and in the correct sequence.. If it's a points dizzy with the key on open the points and check for a spark, this confirms your power supply is good. Quote
gibbon Posted December 23, 2024 Posted December 23, 2024 On 21/12/2024 at 09:47, josh t said: distributor have fuel running to it think I've found the problem Quote
