If you ever need to change the belt, rather than pulling everything out just cut it, pretty much anywhere that deals with conveyer belts will be able to supply a joiner.
I had one in my old lathe, you just get a slight clink noise when it passes over the pulleys lol
AlligatorLacingFastnrsOnBelt_glam_4230ef
I've been taking it to bits to clean.
The overarm support is really bloody hard to move, I've been using the sledge with a block of wood, then once it was forward enough, there are some holes I can get the prybar in. The part of the gib strip I can see looks suspiciously like aluminium flatbar..... Hopefully it's not.
Just because they look like grease nipples on your mill or lathe, doesn't mean they are used for grease. OIL! OIL! OIL OIL OIL OIL !!!!!!!!!!
No wonder it took so much effort to turn the wheels.
I cleaned up the top surface and it's real dark, like black, but I can't feel obvious scoring, so I'm hoping it's okay.
  • Like 8
33 minutes ago, tortron said:
They are still made, gargoyle was a mobiloil brand name
The heavy oil is easy. I'll just use way oil, the stuff I have is super tacky.
But I've not been able to fin out what is the difference between 'grease BB'(apparently a bearing grease) and 'grease cn medium'.
Gargoyle Grease CN Medium is recommended where surrounding conditions are dirty and dusty. Applied cold by means of a paddle, it maintains an adhesive, tacky coating on the gear teeth. When contaminated with dirt or dust, it does not form hard deposits that may pack the clearance spaces at the roots of the gear teeth. The dirt laden grease squeezes from between the roots of the teeth, carrying away the grit and leaving the metal coated with a thin tacky film of lubricant
That's from an oil gear information book I found, probably not much help in narrowing down exactly what it equates to in modern terms.
/I've used motorcycle chain lube spray on exposed lathe change gears with good results, they just fling oil everywhere ha
There's a big list of "open gear" grease and sprays available, I'd imagine any are fine (they are literally called open gear grease)
  • 10 months later...
Wow I can’t believe I’ve stumbled on this resto!!!
Not seen any decent pictures or info related to the Victoria early model.
following with great interest and hats off to you for getting in there!
any idea what the gross weight is?
I should update this. Did I forget I made this thread? Hopefully I have more photos.
It's not really a resto. More of a cleaning because it was just packed with grease and gunge.
It's supposed to be about 1200kg. Do you also have one?
The gearing for the knee seems REALLY tight, up or down. It's a two handed job just to turn the small hand wheel. It's like the gears are meshed too closely, but there's no adjustment. I'm planning on making a flip out handle so I have more leverage. The later and bigger ones have a long handle rather than a small wheel as far as I know.
