  • Replies 163
  • Tiger Tamer
    164
I have the Hillman engine out and the engine bay ready for the first see how it fits. Also the bellhousing mounted on the back of the engine with the obvious in the way, need replacing parts removed. The gearbox turned up today and is a whole lot fatter than the tiny Minx gearbox. Overall the shifter should come out in the same position as the Minx, so that will be helpfull.
Nearly stripped out. I am going to have to set the engine back 100mm max so the firewall will have to be cut a little into the heater box area. I will also need to open up the front opening of the gear box tunnel.
It's good by the steering box so I will need fit a steering rack and steering column. I would think a Avenger or Mk2 Escort column and rack may work. I know how to set up a front steer rack on these cross members but you end up with a turning circle of a Bedford truck. Perhaps a new cross member with Mustang 2 components maybe a better way to go.
Here is a comparison custom x member which was built for the Sunbeam Tiger which just happen to use the same x member as the Mighty Minx :smile:. Something like this would be ideal.
A bit more progress. I removed the intake and water pump which you need to do to get the intake off. I have the engine in the position I want it, which clears the cross member and means I can mount a front steer rack, the same as the Sunbeam Tiger. Made up the engine mount brackets and hangers which mount to the old steering box mounts. I found some poly mounts for a BMW.
  • Like 8
I am told that the steel is too thin and should be 6mm for engine mounts which is at least twice as thick as anything stock. I will change the design and extend the hanger so the mount sits another 30mm lower when i remake it, but for now I have it stable where I want it.
I have bought a MX5 steering column and rack and a MR2 elec hyd pump for the steering. I know the rack and pump will work and hoping the column will be usable as well.
A Pic of the rack sitting how it would for a Sunbeam Tiger. I could mount the rack here but I would really like it to go back further closer to the engine. It would be nice if the hyd fitting in the center could be relocated so I can set the rack closer to the engine. The further I can get it back the less of an angle the tie rods will have to the steering arms. Someone told me he had heard the tube can be spun on the aluminium which would have the same effect. I will need to speak to a rack reconditoner i suppose.
I am going to need to find a oil filter relocation kit and straighten out that rubber water hose. Also notch the inner guard support, but it's looking like it will work.
The cooper primed bracket is just tack welded in place to the brake and clutch brackets as they are the most solid place to weld it to. I will weld it fully after it's given the OK. Two extra bolt holes were for my MK1 attempt.
The steering shaft is just a bit long with the rack in this position and I want to move it closer to the engine so hopefully I can have it shortened. The pin holding it together at the column end can be removed so hopefully the shaft can be shortened and the pin hole re-drilled. Probably hardened steel so I don't know.
The new K Power intake turned up today. Only took a week to get to me once sent and came straight to me without getting stung with gst etc.
Can a moderator move this to the project build and i will start a discussion thread Pleeease. Sorry for getting it wrong at the start.
Radiator mount sorted and working on the fan mounts. I need to get back to the steel shop to get some more 3mm flat.
Also checking the fit of the intake. It's good that I don't have to notch out any more of the firewall.
  • Like 8
