Hillbillyracing Posted May 11, 2019 Posted May 11, 2019 Im using H190 6stud diff from D21 ute (hf43) in my Austin. But would like to use a LSD there is a guy up up the road from me with a heap of 720 and D21 ute and ramdom diff laying around most with no id tags, some diffs with no numbers stamped on the housings and the brakes rusted so i cant turn them over.There is one with a big N1 stamped on the housing LSD? Ive goggled with not much luck, So what im i to look out for? Thanks. Quote
RUNAMUCK Posted May 12, 2019 Posted May 12, 2019 I dont know the answer, but LSD's pop up in japan all the time. Most are 3.7 ratio though. Quote
smokin'joe Posted May 16, 2019 Posted May 16, 2019 find someone with an F code Toyota centre and check the spline fitment, as easier to get LSD from Altezza I know the smaller H165 is same spline as Toyota T and they can be trans-fitted with some tweaking . 1 Quote
