Flash's 1965 Ford Thames
Flash
  • Replies 715
  • Flash
    716
And that's the other side done.
I'm holding off on installing the hubs, discs and callipers for now as despite earlier reports I'm attempting to source a new set of rotors.
My local spares shop says only one set left in Straya and they want moonbeams for them, so I'm investigating other suppliers.
I didn't feel like dragging the welder out today, so thought I'd make a start on the gear selector cover.
Earlier in the week my good mate Cameron swapped some 3mm aluminium offcuts for a bottle of red wine. I got him to guillotine me some spares in case I cock anything up.
First step was to cut the opening for the gearstick out of the top plate. The plan is to use a small aluminium angle strip hidden on the inside of the panels and then glue everything together with panel glue.
  • Like 8
Speedo Cable - Chapter 1
I've been shying away from looking at the speedo cable for a while, but now that I am approaching the pointy end of the project, I thought I'd best put on my big boy pants and tackle the issue head on.
Rummaged around amongst the shrinking pile of parts languishing in the back of the Thames and pulled out the original Thames cable as well as the HiAce one that I pulled from the donor van.
Comparing the gearbox ends of each of the cables I can see that they are way different in terms of the way each inner cable terminates as well as the method for fixing the outer sheath to the gearbox housing.
Photo below shows the two cables side by side:
Speedo Cable - Chapter 2
Next I compared the speedo gauge side of each cable.
Surprisingly the square drive on both inner cables look to be the almost the same dimensions. Who would have guessed?
Looking at the outer sheaths the Thames one has a big nut whereas the HiAce one has a moulded plastic clamp.
Again, side by side photo included below:
Speedo Cable - Chapter 4
With the way forward finalised all I need to do is give the cable a bit of a birthday before I chuck it in.
Talking about that there is one minor snag. The cable needs to pass through an existing 19mm hole in the cabin floor. Only issue is that the plastic retainer on the Toyota cable measures 24mm so I'll need to open the hole up a bit with my step drill. Hopefully I've got an appropriately sized rubber grommet in stock.
I'll only know how accurate the speedo reads once I've done a road test. There is a place in Victoria who supply a little calibration box that the hot rod boys use on the 5 speed Supra gearboxes and I'm hoping that one of these will work with the HiAce speedo drive.
Time will tell, I guess.
Slapped a few coats of 2K black on the rear axle today.
In between coats I gave the gear selector cover a light tickle with some sandpaper so it's now ready for a splash of primer next time I've got a gun full.
  • Like 8
Vegetable eating day today. One you don't look forward to, but you know you'll feel better once you get through it.
Used a combination of degreaser and the wire wheel of death to clean decades worth of crust off a few rear axle related parts.
The smaller brackets are now languishing in the vinegar bath and I rewarded my efforts by splashing a bit of "eau de rattle can" on a few of the bigger parts.
I'm hoping that the calliper paint will be okay on the rear drums.
  • Like 8
Took a trip to the local wreckers today and picked up a replacement Mitsi Express gear selector mechanism to replace my current one which has seen a bit of hackery in the past.
Looked suitably crusty but I stripped it down and then gave it a tickle with a wire wheel and its now languishing in a vinegar bath.
I've got the bushes and swivel pins soaking in degreaser.
Will give them time to mellow and then a quick spritz of paint and it should be good to go.
I've spent the last few mornings rebuilding the rear brakes with the best bits harvested from the two Toyota back axles that I have. The backing plates needed a good clean and I gave them a protective coat of fresh paint before assembling everything.
Managed to get the back axle re-installed just before I packed up for the day.
Tomorrow I'll install the drive shaft and back shocks and then it's just a case of connecting up the rear brake line.
It's going to be interesting to see how bleeding and testing the brakes goes.
  • Like 8
Kicked the day off by pulling the gear selector bits out of the vinegar bath. Gave them a quick rinse in warm water and they are looking lots better.
The base plate is back in a vinegar bucket to do the front part that hasn't been in the solution yet.
I also dropped in the pivot pin as the flat end is still looking a bit crusty.
First thing this morning I pulled the gear selector base plate and pivot pin out of the vinegar bucket.
Front end of base plate is looking mint as is the pivot pin.
I've put the other end of the base plate back in the bucket and hopefully that will sort out the last of the rust.
  • Like 8
