Speedy88 Posted January 14, 2019 Posted January 14, 2019 Hi chaps, Travelling around, just done my WOF and failed on a few minor things, nothing I can't sort myself. Failed on surface rust on radiator support panel. Anyone got some space near Invercargill that I can use in exchange for some beers? Maybe some power tools? Also - does surface rust need to be cut out here? In the UK we just grind it back and paint. Quote
Speedy88 Posted January 14, 2019 Author Posted January 14, 2019 Well, I should have all the parts by tomorrow, most of it is pretty straight forward but I'm happy to hang around for a day or so Quote
kyteler Posted January 14, 2019 Posted January 14, 2019 Depending on the time of day I might be able to help you out. What tools do you need and what needs done? Quote
Speedy88 Posted January 14, 2019 Author Posted January 14, 2019 Thanks, that would be awesome! I can work around you on time. I need to fit a new ball joint, rear shock eyelet bushes and deal with the surface rust on the front rad support. Ball joint not a problem, a proper jack would be helpful if you've got one. Bushes should be easy enough but a vice would make life easier if you have one. The rust I'm not so sure about. Is it normal to just grind down and paint here? It's just surface rust, I'm kind of surprised he failed on it. If so, 10 minutes on a grinder if you've got one would be great. Quote
kyteler Posted January 14, 2019 Posted January 14, 2019 Yeah that shouldn't be a problem. I'll message you when I get home from work tomorrow with the address if you still need it then. 1 Quote
kyteler Posted January 14, 2019 Posted January 14, 2019 Grinding the rust isn't a problem if that's all it is. If it needs welded we can do that too though. Quote
Speedy88 Posted January 14, 2019 Author Posted January 14, 2019 Legend! Thanks dude. Speak tomorrow. Quote
Lord Gruntfuttock Posted January 14, 2019 Posted January 14, 2019 Glad you're sorted. Thought of offering my place if you were stuck, but garage & shed both full of crap that needs shifting before any tools can be found/work done... Quote
Speedy88 Posted January 15, 2019 Author Posted January 15, 2019 All sorted, many thanks @kyteler for the garage tour and help 7 Quote
kyteler Posted January 15, 2019 Posted January 15, 2019 No worries man. I would suggest going up through central to make your way towards chch. The east coast is tedious straights of flat land. 4 Quote
kiwi808 Posted January 15, 2019 Posted January 15, 2019 11 minutes ago, kyteler said: No worries man. I would suggest going up through central to make your way towards chch. The east coast is tedious straights of flat land. ^THIS! @Speedy88 Central Otago is lush at the moment. Lots of cherries and peaches and wine and suns and all the good stuffs. 1 Quote
Lord Gruntfuttock Posted January 15, 2019 Posted January 15, 2019 Can recommend the real fruit ice creams in Cromwell... 2 Quote
Speedy88 Posted January 17, 2019 Author Posted January 17, 2019 Alright, awesome! I think we're heading up to Mt Sunday anyway for predictable tourist reasons so I'll give the coast a miss. Top tips! Quote
