kws Posted June 3, 2019 Author Share Posted June 3, 2019 I tested the fuel pressure today. The FPR is rated at a max of 3BAR (43psi). At idle, with the vac line attached, I had 50psi. With the vac line attached, according to the manual, I should see 6-10psi less than 43psi at idle, so should have about 35psi or so. New FPR is on the way, so will see what happens when I replace that. Fingers crossed. 2 Quote Link to comment Share on other sites More sharing options...
