Thphantum's field drain revival
Thphantum
It is a blocked/ worn out field drain from my septic tank system. I'm creating a new section of field drain to dispurse the fluid from the system. In town you just hook up to the sewer, in the country you need your own system. Soak holes do the same job but the water table is too high where i am, so field drain is the best option.
So now comes the technical bit, Using the grinder we cut slots on the pipe at 500mm intervals. Next we glue the sections of slotted pipe together and place them in the drain keeping this section pretty much level, (thanks to Ray the builder for use of his laser level). This is where the poos water will run too and evenly dispurse through the slotted holes if I have done everything correctly.
