Willdat? Posted August 2, 2016 Share Posted August 2, 2016 Any good sources for the plugs shown above so I can make my own adapter? $100 otherwise out of the USA. Cheers edit: oh and because it's not obvious I just need the 6 and 2 pin plugs. Quote Link to comment Share on other sites More sharing options...
SiRge Posted August 2, 2016 Share Posted August 2, 2016 Pick a part man, have done it heaps of times before. More than likely the distributor plugs form the same era will be the same. I made an OBD2 to OBD1 distributor adaptor harness for like $3 1 Quote Link to comment Share on other sites More sharing options...
DB8-TypeR Posted August 3, 2016 Share Posted August 3, 2016 Super easy to just pull the pins out of your plugs and pop them into the new ones too Quote Link to comment Share on other sites More sharing options...
Willdat? Posted August 3, 2016 Author Share Posted August 3, 2016 Pick a part man, have done it heaps of times before. More than likely the distributor plugs form the same era will be the same. I made an OBD2 to OBD1 distributor adaptor harness for like $3 No pick a part in Nelson unfortunately - fortunately the engine seller is now sending me the original ones off the DOHC ZC. Seeing as it has taken him almost 2 months to get it to me I guess it's good that there is a silver lining! Quote Link to comment Share on other sites More sharing options...
SiRge Posted August 3, 2016 Share Posted August 3, 2016 Can always take a photo of what you need an someone could get if for you no doubt Alternatively there's an classic honda guru who lives in Nelson who might be able to source a part from spares etc Quote Link to comment Share on other sites More sharing options...
