d.p.n.s Posted August 1, 2016 Share Posted August 1, 2016 hi all 81 ex lancer 1800 ......does it have a manual or electric fuel pump and if so where is the little bugger. cheers Quote Link to comment Share on other sites More sharing options...
piazzanoob Posted August 1, 2016 Share Posted August 1, 2016 I havn't had a look at a ex lancer but could possibly have a electric pump in the fuel tank pull up the back seat and check for a wiring plug or for some screws or bolts in a round shape undo and pull out and pump will be there Quote Link to comment Share on other sites More sharing options...
d.p.n.s Posted August 1, 2016 Author Share Posted August 1, 2016 I havn't had a look at a ex lancer but could possibly have a electric pump in the fuel tank pull up the back seat and check for a wiring plug or for some screws or bolts in a round shape undo and pull out and pump will be there cheers tanks in the boot floor.might pull up the boot lining and have a look. Quote Link to comment Share on other sites More sharing options...
OSM Garage Posted August 1, 2016 Share Posted August 1, 2016 If its a carb motor it will be a manual fuel pump - Located in the middle of the inlet manifold. If its injected obviously it will be electric fuel pump - Located above the L/R wheel well Quote Link to comment Share on other sites More sharing options...
d.p.n.s Posted August 1, 2016 Author Share Posted August 1, 2016 If its a carb motor it will be a manual fuel pump - Located in the middle of the inlet manifold. If its injected obviously it will be electric fuel pump - Located above the L/R wheel well cheers mate. Quote Link to comment Share on other sites More sharing options...
