alternator wiring
maxted
going from a external to internal regulated alternator, I'm wiring up the new alt and it has 3 terminals R and L on the plug and B+ stud, i found this image on the net just wanted to check it was right. should the b+ have constant power straight from the battery? or just when the ignition is on?
No, you need like 40-100amp depending on what the alt is. You can use a modern fuse holder thing instead of a fuseable link which are easy to check/change. Fuseable links are sweet and easy to use also though. It's just a bit of thin gauge wire that is made to burn out at a certain current, but it from the internet or maybe a local shop and solder or crimp in. The alt wire should be a decent gauge you will need a pretty decent crimper to do the terminals.
