Crispen Posted July 30, 2015 Share Posted July 30, 2015 Hey peeps It has the original 1.3 in it and the carb has just started to play up and springs arnt working like they used to. I wish to upgrade to something kinda cheap but effective until i finish my 1.6 off. What other carbs can bolt stright onto the original manifold... My friend has 1600 nikki carbs from a gemini, could these work?. Any idea where i can get linkage kits or can i jimmy something up? Also if anyones got a 1600 crankshaft thats not buggered, give us a buzz! Chur Quote Link to comment Share on other sites More sharing options...
piazzanoob Posted July 30, 2015 Share Posted July 30, 2015 You could just buy a rebuild kit for the current carb but I'm not sure weather they come with new springs or not. Quote Link to comment Share on other sites More sharing options...
bmxnz11 Posted July 30, 2015 Share Posted July 30, 2015 Not sure any upgraded (thinking twin throat) carbs will be able to bolt straight onto the original manifold. As above, get the original carb fixed, they're cheap as to buy a few and make a good one. Otherwise it'l have to be a new manifold to suit what ever upgrade you go for. 1 Quote Link to comment Share on other sites More sharing options...
J-W-G Posted August 2, 2015 Share Posted August 2, 2015 If you want a 32/36 Weber youll need the manifold aswell, the single throat has a totally different mount Quote Link to comment Share on other sites More sharing options...
