uza63 Posted June 25, 2015 Share Posted June 25, 2015 So went to bridge the two pins to find the t1 or t## is missing, the engine is a 5le so not exactly efi but its got a diagnosis port with maybe 5/6 pins out of 14? Its the same port as all 90s toyotas. Have issue with abs light coming on Quote Link to comment Share on other sites More sharing options...
Yowzer Posted June 25, 2015 Share Posted June 25, 2015 IIRC the ABS diag is separate from the engine diag. But yuh a pin's missing and I have no clue on how to pull codes from those silly things. / no help. Quote Link to comment Share on other sites More sharing options...
smokin'joe Posted June 25, 2015 Share Posted June 25, 2015 i often found the hilux abs fault was often wheel sensors covered in crud, or wiring damaged near sensors Quote Link to comment Share on other sites More sharing options...
