riba Posted May 8, 2015 Share Posted May 8, 2015 as above. as I have no idea where the map sensor is or if it has one an need to wire it up to my gx61 Quote Link to comment Share on other sites More sharing options...
HighLUX Posted May 8, 2015 Share Posted May 8, 2015 What was your 1g originally out of? Quote Link to comment Share on other sites More sharing options...
1Gesus Posted May 8, 2015 Share Posted May 8, 2015 I cant remember ever playing with a map sensor when changing motors etc. They have the AFM obviously on the intake. Maybe a map sensor for the factory pressure gauge? Quote Link to comment Share on other sites More sharing options...
riba Posted May 8, 2015 Author Share Posted May 8, 2015 was out of a gx71 mark ii Quote Link to comment Share on other sites More sharing options...
HighLUX Posted May 8, 2015 Share Posted May 8, 2015 If its a later model 1g it will run a map sensor instead of AFM. Will be a small 3/4 pin oval plug on the loom that will be near the back of the engine as the MAP sensor mounts on the fire wall behind the intake manifold usually Quote Link to comment Share on other sites More sharing options...
Stu Posted May 8, 2015 Share Posted May 8, 2015 Being a later model ecu it 'may' have the pins labelled on the board if you take the lid off. If it does look for the 'PIM' id - thats the map sensor input, find the wire colour and it should be easy from there either visually or with a multimeter. Quote Link to comment Share on other sites More sharing options...
