in need of a wiring diagram for jap spec 1gge
riba
If its a later model 1g it will run a map sensor instead of AFM. Will be a small 3/4 pin oval plug on the loom that will be near the back of the engine as the MAP sensor mounts on the fire wall behind the intake manifold usually
Being a later model ecu it 'may' have the pins labelled on the board if you take the lid off.  If it does look for the 'PIM' id - thats the map sensor input, find the wire colour and it should be easy from there either visually or with a multimeter.
