d.p.n.s Posted April 28, 2015 Author Share Posted April 28, 2015 What a mount that bolted to the strut mounts like s horse shoe shape that bolted the caliper on the other side of the strut? Quote Link to comment Share on other sites More sharing options...
tim13 Posted April 28, 2015 Share Posted April 28, 2015 is it possible to machine just the mounting half of the caliper to create room for an adapter to link it all together ? Quote Link to comment Share on other sites More sharing options...
tim13 Posted April 28, 2015 Share Posted April 28, 2015 can you swap struts left to right and would that give more options and clear steering ? Quote Link to comment Share on other sites More sharing options...
d.p.n.s Posted April 28, 2015 Author Share Posted April 28, 2015 can you swap struts left to right and would that give more options and clear steering ? Will have a look at that in the morning mate Quote Link to comment Share on other sites More sharing options...
J-W-G Posted April 28, 2015 Share Posted April 28, 2015 Try FD or FC rx7 calipers as they fit well with the TX3 brake upgrade. I didnt use mine cause i found some princess calipers and couldnt be arsed making the rx7 ones fit. They are a 160mm bolt spacing and are for a 20mm disk if i can remember Quote Link to comment Share on other sites More sharing options...
sr1600 Posted April 28, 2015 Share Posted April 28, 2015 Room to chuck a 6mm spacer between the hub and disc? Then you have 6mm to make an adaptor bracket. Quote Link to comment Share on other sites More sharing options...
