uza63 Posted April 13, 2015 Share Posted April 13, 2015 I have a turbo dash im wanting to put into a non turbo car, 81 celica. The plugs are the same, I stripped it, swapped the odo's over to get my kms, but when plugging in found its crazy, fuel gauge works constant, turbo lights constant, oil pressure works when ign off but not on, I mean its obvious the wirings different, I guess im hoping someone has done this before and maybe has an idea of wiring diagram for the ta63's Quote Link to comment Share on other sites More sharing options...
thegreatestben Posted April 13, 2015 Share Posted April 13, 2015 Toyotas have different senders in tank between digi and non Quote Link to comment Share on other sites More sharing options...
uza63 Posted April 13, 2015 Author Share Posted April 13, 2015 digital dash has diff plugs, im using the analog turbo dash Quote Link to comment Share on other sites More sharing options...
Stu Posted April 13, 2015 Share Posted April 13, 2015 While I havent swapped over your particular model Ive converted quite a few other Toyota dashes . Its a bit of buggering around but you can decipher most of the pin designations by tracing back from things like IG- (tacho), oil light, alt light etc just by following the circuit routes on the board. The pins in the plugs easily pop out (use a pick to bend the little tab out of the way) then repin accordingly. If you put up some photos I might be able to determine what some of them are by wire colour. Quote Link to comment Share on other sites More sharing options...
