Kiwibirdman
Kiwibirdmans 1962 EJ Holden Wagon
The story of the gutter trim. The gutter trim on a EJ wagon is about 2.5 metres long and nice ans flexible. I had spent about 2 or 3 hours cleaning it up. knocking the dents out and polishing. It was getting late and I was hell bent on getting it done and on the car.
I had had a couple of warnings that the trim was getting flicked off the wheel, trying to get to the edge on the bend at the front is a bit of an art. Should have stopped but ...........
I was lucky, one bruise on my are and only the trim turned into spaghetti. I still haven't worked up the nerve to do the new one.
  • Confused 1
  • Sad 5
Share this post
Link to post
Here are some photos
The bumpers look pretty good, the front and end of the rear are new reproduction ones, the front overriders and centre of the back were re-chromed.
Bought this flaring tool the other day for the fuel lines, works really well, $55 off trademe.
Share this post
Link to post
I put the hoodlining in myself. It looks better in real life but with 20/20 hindsight I should have put it on a trailer and taken to the professional.
hopefully overtime it will tighten up a bit.
Share this post
Link to post
This is the cold airbox I built.
It has a pipe that comes from beside the radiator which feeds the box. It isn't totally air tight but I'm working on the principle that air pressure while driving will make positive pressure so the engine will get cold air.
  • Like 9
Share this post
Link to post
Despite being side tracked with work family life in general there has been some good progress.
All the side window are in. I had a problem with the left rear door, the channel that the rubber goes in was missing. This was a door I bought to replace the original. I bent up a channel and pop riveted it in. From the factory this was spot welded but since I have nice new paint the welder was staying far away.
The next job was the rubbers and channel then drop the window in the hole. the whole process felt harder than the other side I did a while ago. When I went to put the quarter window and channel in I found the gap was 5mm too small. Managed to carefully spread the door using a couple of small pry bars. Managed to scratch the paint on the inside of the door on the first go, second go worked like a charm.
Spent hours making up hard fuel lines.
The rubber bits joining the hard lines have been done.
Share this post
Link to post
