Kiwibirdman
Kiwibirdmans 1962 EJ Holden Wagon
A month since the last update, where the hell did that go????
Front brakes are almost done, HZ Calipers fit over the machined down HQ discs. I had to play musical brake parts, HZ calipers stolen off the Firebird. I had some HQ calipers that I had rebuilt a while ago. A small amount of grinding was required and some new bolts and the Firebird has new calipers.
I did a list yesterday of the jobs that need to be done. There are a lot of things that will take 10 minutes to finish off, mainly welding jobs.
I will take some photos and get them up.
Share this post
Link to post
Still no photos, must work out how to get them off the new flash phone. Replaced the rotten section of the trans tunnel over the weekend, a big chunk more of the rust done. I bought a length of 9/16 High tensile steel bar to replace the wooden intermediate steering shaft. I needed a 320mm length and the standard length was 3.7 meters. It did only cost $40.
After 2 goes I got the the flats for the cotter pins in the universals in the right place. Steering shaft has been trial fitted and everything clears...........just. If anyone needs 9/16 round bar I have 3 meters  looking for a home.
I pulled the engine out last night to get some space to finish off the trans tunnel final rust by the gearbox and sort out the gear shift. New morse type cable and fitting are turning up at the end of the week. Also turned up is a Aliexpress cone type air filter.
Getting dangerously close to sending the car off for some paint.
Share this post
Link to post
I called in to the painters to see how busy he is. They have 59 caddie, mid 60s VW, and a why would you bother rusty 57 Chev on top of a heap of Jucy rental vans. I'm booked in for 2 weeks away to bring the car in. Because mine is easy and I have money I get the jump on the others. Now I have a dead line to work to things will get done.
Share this post
Link to post
At the last monthly meeting I got told off for not putting up photos.
Here are some updates. Section of the trans tunnel that looked like swiss cheese cut out
New section welded in. Sounds really easy in 2 pictures but took about 4 hours to get right20170909_180301.jpg.629ed9a173d9e198463f6ecd929b0824.jpg
And some more swiss cheese gone as well as the big cut I put into the tunnel to make the trans fit welded up. 20170921_213000.jpg.a65a8b0e1f173887ef6fb977154ba75b.jpg
Here is the steering shaft. With universals fitted. Amazingly enough nothing touches. The lip on the chassis rail will get removed beside the shaft as a precaution.
Share this post
Link to post
 Here is another view of the steering shaft
A photo of my extra length of 9/16 bar if anyone needs some. Engine is back on the stand waiting for wiring, sorting out fuel lines, dip stick.........
First seatbelt mounts installed. The one by the door way and the hole in the trans tunnel are in the original places, The plate on the floor is for the centre belt.
And the other side. I used bolts on the plates as per the lvvta manual and they pulled up nice and tight to the floor. The thing that looks like a a shark fin is the mount for the handbrake return spring. Originally it was a tab off the floor. I'm worried about drive shaft clearance to mad it longer
Another job ticked of the list was welding the pad to the brake pedal.
20171002_190935.jpg.1c885d5c005614f6bd528519447580d6.jpg20171002_190915.jpg.dd11fefe3dc047b7b65f679bf59ac6e3.jpg
Comments and ideas welcome as always
Share this post
Link to post
Over the weekend I pulled the front of the car apart. Front suspension is spread around to fallen over, front chassis/inner guards are up on saw horses. Tonight we finished off all the welding on the front section. Ready for paint over the next few days. I feel like real progress is being made, looking forward to painting stuff and final assembly. I went to see the painter and got the "realistically I can't do your car this side of Christmas". I not too bent out of shape, it gives me time to paint the underneath, engine bay etc and assemble the car to the point where it will be driveable. There are lots of small but time consuming jobs to do, like make a mount for the wiper motor and fix the linkages, sort out the handbrake cables. It is probably better the car has the engine in before painting so it is all good.
If there is anyone out there who is familiar with injected Holden V8's especially the VT version, I have some questions.
Share this post
Link to post
Here are the photos. RH suspension.
Back to the future. This was the view for so long, nothing forward of the firewall
Front on saw horse ready for welding
Gussets as suggested by @cletus
And the other side, also with the rebate in the joint to clear the steering.
Here is where some space was made for the exhaust. Still a touch with the grinder to knock off the high spots
Got rid of the hole for the throttle linkage
And the one for the choke cable
Share this post
Link to post
I decided to finish work a bit early today and painted the floor. The tin of PA10 I had I think I bought in 1992.
It only took about half an hour to mix in all the hard stuff from the bottom of the can.
20171016_195059.jpg.49122f0b92b98b20446843dadcbb8ef0.jpg20171016_195102.jpg.917916b2196bfc3341948a467f0309fb.jpg
It feels good to have paint on something. I will clean up the rest of the floor and make it all nice and red.
Share this post
Link to post
I am giving myself a kick in the backside for not updating this thread, 4 months is way too long. There has been much work done on the car as well as a job, kids, wife, holidays and all the other stuff that gets in the way.
After putting most things together the car got pulled apart again for lots of painting. The floor got every seam sealed then painted with 2 coats of a water proof product from a crowd called Duram. This was then covered by underseal from a bunch of rattle cans. I'm pretty happy the way it has turned out.
The front has been painted and all put together, front suspension installed. I had a pair of springs that have been sitting in the garage for a very long time. Not sure what they came out of but the dimension is GM and they went in. They are fairly low so hopefully will work out OK.
I fitted the hand brake cables yesterday, The EJ rear cable got put into the HZ drums all appears to be good. I now a brakes that work on the back wheels.
Engine should be going back in this week then let the wiring begin. I want to get the car mobile before painting and get the OK from @cletus .
Photos to follow.
Share this post
Link to post
Here is some proof that work has been done.
Front suspension together, HZ Calipers on HQ disc's milled down 12 mm
Front back on the car and painted
Strong back added to engine mount adapter plates on the advice of @cletus.
20180210_143813.jpg.235fedfd223d3e3d16594c44f4a095cf.jpg20180210_143813.jpg.235fedfd223d3e3d16594c44f4a095cf.jpg
New boots on the steering rack. I will clean up and paint with the same black that everything else is getting. The inside of the rack looked to be in pretty good condition.
Share this post
Link to post
Monthly meet was 2 weeks ago and engine is still on the stand. I started the brake lines in the engine bay. It was a good move as it took all the space I had to get them routed around all thr obstacles. I only stopped tonight beacause I ran out of P clamps. I'll buy some more tomorrow and finish it off Friday. As long as the wife lets me get on with it engine in this weekend.
Share this post
Link to post
Engine went in on Saturday. I attached the wiring loom to the trans and draped the rest of it over the motor. The engine went in ok. I was using an engine crane and really needed an extra set of hands. Rang a few people but no one wad around. Decided to go for it and all went well. After fitting the engine i decided that the drivers side exhaust should go on. Used a block of wood on the jack to lift the engine. The jack decided to move which kicked the block of wood out. That jammed my ring finger against the chassis and mage a nice mess of my finger. Many bad words yelled and blood on the floor.
I have photos that i will put up once my pc has finished updating.
Share this post
Link to post
I put the drivers side header in Wednesday night. I put the front back up on stands to get a bit of height and used my trusty length of 4x4 on the jack to lift the motor. All good this time, no more busted fingers. One issue.......
I have decided that this needs to be called the twice done car with the number of things that have been done and then redone.
The left hand pipe goes to the drivers side brake so this can be moved away a bit, the other one goes around the front of the motor so it will get rerouted up in front of the exhaust.
Share this post
Link to post
Since it is the Auckland monthly meet tomorrow I thought that a bit of progress is in order. I have been distracted with doing wood working on the house, spending time with the family and having to earn a dollar or two.
The plan was to have a look at the passengers exhaust manifold and make sure everything clears, fit the drive shaft and possibly the drive shaft loop. I'm tryng to clear as much stuff as possible from the garage floor and put it on the car.
First off I couldn't get the manifold in. Turns out the car has to be jacked well clear of the floor. The brake lines are almost OK, 50mm clearance as according to the book except for the last bit. Easy fixed by cutting the end off the pipe and flaring again. The big issue was the wiring loom for the engine came out where the exhaust is at the back of the motor. No way of pulling the loom up, only 10mm of gap to the firewall and about 30mm of loom. Engine will have to come forward which means taking it off the mounts and making space. Not hard but will chew up a fair bit of time and swearing.
Drive shaft and loop are still on the floor.
On a positive note my brother in law is printing off a copy of the wiring loom and plug pin outs I got off the interweb. Let the fun begin over Easter.
Share this post
Link to post
Easter has almost been and gone. The problem with having a wife,kids, house, other cars and a life is things get in the way. I got the Silverado cleaned and wheels swapped end to end(good bye 4 hours all up) painted a ceder wall on the house ( 2 coats and look amazing but day gone) as well as 2 dinners out and 20 people round for Easter Sunday brunch. A good weekend but not much on the car.
I did get the wiring loom out without having to pull the engine. I spend a lot of time with the wiring diagram and the spaghetti that passes for a loom. The loom is in 3 main parts that I need. The power train loom pretty much all remains. I'm going to tidy it up and a few things get moved around. The knock sensor has been moved to the other side of the motor and I'm shifting the ignition module to the fire wall so that part of the loom will be about a metre shorter. Some careful work with a soldering iron and heat shrink will be good here.
The loom that has the main power ( battery, feed to the starter and alternator) will also remain with a couple of fuses that have to be mounted. The Main Wiring Harness only has a few bits that I need, mainly the relays for the fuel pump, EFI and Engine fan. So most of this loom can go and the more I think about it using the feeds off the original loom for the car I can switch the relays using the original ignition switch.
What I really need to do is write another list and just start knocking things off. Once all the big stuff is mounted in the engine bay (radiator, air intake) then the smaller stuff (ignition Module, relays, fuses) can be mounted.
Share this post
Link to post
After posting last night I found a guy on trade me who does wiring loom modifications. I spoke to him this morning and the more I think about it the better the idea is.
The looms he does will have the relays and fuses mounted under the dashboard which gets some stuff out from the engine bay.
Time for a bit more thinking and checking the piggy bank.
Share this post
Link to post
Finally some time in the garage. Drive shaft is in and started playing round with the driveshaft loop. Here it is bolted together on the bench
The box it came in must be something special or I got ripped off, $100 from STA parts.
There is a flat area on the floor that will let me mount the loop just behind the UJ. I have cut the mounting parts down by about 2/3 and drilled new holes. I still need to make the backing plate out of some 3 ml plate, tomorrows job.
I ordered an ignition module to replace the one that never came with the motor, that turned up a couple of days ago.
Lastly had a good talk with the guy who does the loom mods. Turns out he is a member here @vk327 , NZ is truly a small place.
Share this post
Link to post
Well overdue for an update. Been side tracked with giving the 2 bedroom flat in our basement a full birthday, repainted everything, new carpet and lino, new toilet, vanity etc etc. All finished now and new tenants moving in next week end. Work has been mad busy as well and to be honest going down into the garage when its cold and the fire is on has lost its appeal.
Anyway enough there has been progress. I pulled the new alloy Gemini radiator I bought a while ago out of its box and sat it in place. should be all good once the hole in the support panel is trimmed back 10mm on each side. I had the top panel blasted and painted, it just needs a quick blast of rattle can black to match the rest of the engine bay.
I went to bolt it in place and found that all the captured nuts are full of paint and crap. I went to the local bolt shop and bought replacement bolts for the guards and front panels. About 45 1/4 UNF bolts with flat washers and spring washers and a tap to clean up the threads. There are a few 5/16 bolts as well. Even though each item is cheap all together it starts to add up.
I have had the modified wring loom from @vk327 in the garage for a while. Still in the box that he sent it back to me in, I haven't even opened it up to have a look.
I'm heading off for a week tomorrow, family holiday for the school holidays. The following week the wife and kids are away skiing (I wonder why I have no money) so should be able to get some serious garage time in.
Promise photos in the next update.
Share this post
Link to post
