Ford ESC module
Jorden
My zetecs going to be carbed and i want to run it off an esc module as its cheaper than an esc and apparantly arent too bad  :-)  Only needs four wires to run apparantly.
What Fiestas / Escorts have them? do i need the sensors or loom from that car or can i use the zetec ones?
I know that theres a 98 and a 97 escort at pickapart at the moment.
Cheers.
Yea i understand that an ecu will be alot better but im trying to look at the cheapest option, and it apparently doesn't run it as bad as people think. If ive read the pick a part website correctly i can get an esc module for $14 dollars  :tongue:
i have done a bit of resarch into this and have found people have been sucessful on this with only a single carb and no engine mods as the timing control is vacume sensed so if you are running sidedrafts or cams the vacume will be too unstable for an acurate reading causng the timing to jump all around the show better off with aftermarket ecu i would say
